Welcome to the North American Subaru Impreza Owners Club Monday April 20, 2015
Old 03-04-2004, 12:41 AM   #1
will667
Member#: 3175
2004 WRX STi
Default oil change for sti
my sti is ready for its first oil change. i didnt see anything in the owners manual about using synthetic. is that what i should use?
thanks
will667 is offline   Reply With Quote
Old 03-04-2004, 01:27 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can use whatever you want. . .just make sure it's the same weight, i.e. 5W30. Different thought processes regarding when to switch to synthetic though. . .I waited until 10K. . .others did it their first oil change. It's up to you. Just make sure that after you make the switch, you don't go back and forth.
Calvin
cnk is offline   Reply With Quote
Old 03-04-2004, 08:13 AM   #3
will667
Member#: 3175
2004 WRX STi
thanks for the advice
Old 03-04-2004, 04:46 PM   #4
nicrfe1370
Member#: 52292
If switching back and forth from synthetic to non-synthetic was ever inappropriate, it no longer is. I know old habits die hard, but I've never heard a plausible explanation for this one.
Also, mixing viscocities is not a problem these days. Many Subaru owners have done both of the above mentioned deeds, with no ill effects. I have seen used oil analysis reports from these vehicles, so it's not just an alternate version of junk science I'm spouting!
I don't mean to contradict everything cnk says, but I want to try to dispell rumor and myth.
Virtually any oil with an API SL rating will do just fine for daily use in a Subaru, with 3000 mile, or even 4000 mile oil change intervals. If you want top performance, longer drain intervals, or both, a synthetic is your best bet. If you want more oil knowledge than you can shake a stick at, cruise on over to http://theoildrop.server101.com/cgi/ultimatebb.cgi
nicrfe1370 is offline   Reply With Quote
Old 03-04-2004, 05:13 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I would let the motor loosen up on regular oil for 7-8k miles before putting syn oil in it....especially with an easy 1k mile break in.
Too many stories of high oil consumption in engines broken in easy and switched to syn too soon.
And, yes there are many differing opinions but I know that some engines don't use oil and some do....mine never have.
Oil Change for new 07 STI CheWieB0y Newbies & FAQs 1 11-08-2007 05:20 PM
tranny oil change on sti 03wrxtreme Transmission (AT/MT) & Driveline 2 12-29-2006 02:10 PM
First oil change on STI palpullero Service & Maintenance 13 08-24-2005 01:57 PM
My first oil change on STi. Expieriences. LESLIEx317537 STi Forum Archive 70 08-21-2003 12:01 PM
('93-'01) Oil changing for RS and WRX ScoobyBoy Impreza Forum 4 05-27-2001 08:59 PM
