Old 05-30-2000, 01:32 PM   #1
Delverius
Member#: 1122
2000 2.5RS NA
Blueridge Dirty
Question Bottoming out rear susnpension ... ?
Hi All
Thanks in advance for all constructive commentary.
I have noticed recently that my car seems to bottom out if I take a sharp corner or if I have any significant load in the back seat (i.e. passengers). When I corner I can hear a sound as if the car was groaning (like the sound of pressure vessel's hull buckling - i.e. submarine at great depth) Is this the sound of the springs/coils bottoming out on the strut tower. I have also noticed that my tires are destroying the rubber liner on the wheel well because of this. It's already shredded to the point that the metal mesh is showing. Anyone else having problems like this? I am running stock suspension, 20mm swaybar, 16" Focals w/ Bridgestone RE730 tires on a MY00RS.
My guess is that the stock suspension sucks and I've already abused the springs to the point where they are no longer effective. Either that or I drive like a maniac and need some stiffer springs.
I would appreciate any wisdom that experienced car tweakers have on this issue. Thank you.
-Del
Delverius is offline
Old 05-30-2000, 02:05 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
You need stiffer springs or different tires. It sounds to me like you're tires are rubbing against the body of the car which makes that noise and wears them down.
8Complex is offline
Old 05-30-2000, 02:26 PM   #3
Delverius
Member#: 1122
2000 2.5RS NA
Blueridge Dirty
Post
The tires are same size as the stock RE92s. I just upgraded to RE730s. Same size tires and same size wheels. The offset is also the same. The only difference is that the RE730s are about 1/8" wider because of their construction.
I was thinking stiffer springs myself . . .not sure though. All the springs I've looked at lower the car . . which is what I'm trying to avoid.
[This message has been edited by Delverius (edited May 30, 2000).]
Old 05-30-2000, 02:39 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
well one solution is to keep people out of the back seat...hehheh
makes the ol 2 door seem like a good idea.....
-jaxx
what was the offset of the focals?
Jaxx is offline
Old 05-30-2000, 03:20 PM   #5
SubePwr
Member#: 140
1999 RS 2.5
Post
Two Words: Smaller Passengers!!!!
back at ya
Jim
SubePwr is offline
HTML code is On
Bottoming Out Strut? STORER Brakes, Steering & Suspension 5 05-26-2001 12:36 AM
How bad is bottoming out the suspension? IMPREZAmike Brakes, Steering & Suspension 10 05-03-2001 05:12 PM
Why do I bottom out??? CRAZY KEN Brakes, Steering & Suspension 4 02-02-2001 06:53 AM
Jumped & bottomed out! Matt Monson Bay Area Impreza Club Forum -- BAIC 6 01-09-2001 03:30 PM
Bottoming out on Rear Suspension - Advice? Delverius Technical Forum Archive 7 05-31-2000 08:21 AM
