Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 03-04-2004, 11:35 AM   #1
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Default Whiteline KCA375 Transverse Link Bushing Installation
So, who here has installed the Whiteline KCA375 Transverse Link Bushings. I have a set on the way, and was reading the online pdf which explains the orientation you use for the intall. They further go on to explain that if used in the maximum caster position, its possible that the "lower control arm fouling on the chassis rail." After looking at the photo in the installtion doc, i interpret this as the outer edge of the lower control arm rubbing on the frame. Alternatively, it could mean that the bottom side of the control arm may touch the USDM U-shaped impact brace. Has anyone experienced this behavior yet?
PDF:
http://www.whiteline.com.au/docs/ins...253_KCA375.pdf
Jon.
EDIT - Adding some installed pics:
this is the passenger side bushing looking towards the front of the vehicle.
Cosworth is offline   Reply With Quote
Old 03-04-2004, 07:40 PM   #2
rex n effect
Member#: 15289
02 wrx pollen silv
& '11 TDi dadwagon
bump!
rex n effect is offline   Reply With Quote
Old 03-05-2004, 08:30 AM   #3
Vortechcoupe
Member#: 33262
E36 M3
93 notch, X3
nope, is says max "neg" may hit. Your trying to get max positive. Should be fine. Let us know how it works out for you.
Justin C
Vortechcoupe is offline   Reply With Quote
Old 03-05-2004, 10:43 AM   #4
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
You know, you're right! Now thre's a glaring oversite on my part. I'm curious why someone would add neg caster... unless to cancel out some oss cross value. I suppose its wise to warn about it in in case for whiteline as a CYA disclaimer. Thanks for pointing that out, Justin.
Old 03-22-2004, 03:26 PM   #5
rex n effect
Member#: 15289
02 wrx pollen silv
& '11 TDi dadwagon
how hard was this install?
Old 03-22-2004, 03:52 PM   #6
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
easy to get off and back on, find a shop to press in/out the bushing and mark the orientation/direction you want the bushings to go into the housing.
BTW, I have 4 degrees total with the bushings.
TyrannoSullyRex is offline   Reply With Quote
Old 03-22-2004, 04:17 PM   #7
rex n effect
Member#: 15289
02 wrx pollen silv
& '11 TDi dadwagon
Originally posted by TyrannoSullyRex
find a shop to press in/out the bushing...
Is this necessary or just much easier?
Old 03-22-2004, 06:44 PM   #8
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
very necessary, the bushings are pressed in, it takes a ton (just guessing) or so of force to get them in there.
If you weigh alot, and your friends weigh alot maybe you can all eat a couple pizzas each then stand on them and get them in.
Old 03-22-2004, 08:47 PM   #9
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
added some installed pics for reference above. It might be helpful for orientation clues.
Old 03-22-2004, 09:18 PM   #10
Vortechcoupe
Member#: 33262
E36 M3
93 notch, X3
hmm, so these are the STX legal ones right? About how much does a set run???
JustinC
Old 03-22-2004, 09:58 PM   #11
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Yes and $100 shipped from MJP.
Old 03-22-2004, 10:24 PM   #12
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
I removed some material from the washer because I was concerned about it hitting/rubbing on the frame. I just knocked off a bit for peace of mind. I used part of Cosworth's picture to illustrate.
Old 03-23-2004, 12:43 AM   #13
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
STX illegal it doesn't say in the rules you can modify the washer
I was thinking of replacing my Energy Suspensions with these. How much *more* caster did you get with these bushings?
-Tom
trhoppe is offline   Reply With Quote
Old 03-23-2004, 12:50 AM   #14
mlambert
Member#: 13831
oh god tom, illegal washer modifications
mlambert is offline   Reply With Quote
Old 03-23-2004, 07:52 AM   #15
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
nice, tom.
I have 4 degrees (well, 4 on the right, 3.8 on the left) with the JIC tops currently, other tops on the way.
Old 03-23-2004, 11:11 AM   #16
Fred
Member#: 3560
06 STi, 02 WRX
94 Open Light 2.5RS
Tom - mine added 0.5 to each side. (went from 3.0 to 3.5)
Fred is offline   Reply With Quote
Old 03-23-2004, 02:18 PM   #17
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Ahhh, not worth the effort for me then. I have quite a bit more then 4 per side already
-Tom
Old 03-23-2004, 05:37 PM   #18
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
-Tom
oh, that 4 number will go up quickly once some new plates go on the car.
Old 03-23-2004, 06:58 PM   #19
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
-Tom
Every little bit is something... plus the hard duro bushing is great for turn-in crispness. But you probably already have poly in that spot, right?
Old 03-24-2004, 01:53 AM   #20
MNbiker
Member#: 18148
'08 WRX
Dark Gray
find a shop to press in/out the bushing........
Good advice, unless you happen to have a decent press at home. My 6 ton press BARELY managed to push the bushing out when I installed these things.
-Steve
BTW - I found a coupler for 1 1/2" OD steel pipe that was EXACTLY the correct diameter to use as a die for the press. It, plus a screw in cap cost me all of $4 at Home Depot.
Tom - I got .5 degree more positive caster as well. And the harder bushings do feel crisper as well. In fact, they have me wanting some poly bushings for the front LCA's as well.
MNbiker is offline   Reply With Quote
Old 03-24-2004, 10:49 AM   #21
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Thats interesting... I didn't find any rubbing from the washer to the frame. The clearance was tight, but there was enough room. The action is not concentric and the washer is true and round so i don't suspect any touching to occur. I suppose that if your bushings were installed slightly off and rotated up some, you might impact the frame, but in the proper exact orientation, it seems fine.
Jon.
Old 03-24-2004, 10:56 AM   #22
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Jon.
Even though it's a stiff as hell bushing, I was still concerned with it moving a little and fouling up stuff, it was just a little close for comfort.
me too, where do I get some of those without buying an entire set of bushings of which I'll only need two.
Old 02-07-2011, 11:42 AM   #23
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
I'm bumping this old thread because I want to understand exactly how these work. I had a local shop press these bushings for me and I installed them last night with the offset towards the outside of the car for maximum positive caster according to the instructions.
My question is this - how does moving the rear of the control arm towards the outside of the car increase caster? It seems like it would affect toe more than anything.
Also, I do plan on getting an alignment in a week or so, I will post the before and after results.
thrasher is online now   Reply With Quote
Old 02-07-2011, 11:45 AM   #24
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
They move the wheel forward a bit and very much also affect toe (you need an alignment ASAP).
And this isn't an old thread, it's ancient.
A-man07 is offline   Reply With Quote
Old 02-07-2011, 11:49 AM   #25
thrasher
Member#: 40579
2002 WRX Stage 2+
^^^Thanks.
My car is not a DD, so it will not be driven until the day of the alignment.
Impreza Front suspension bits, oem control arms, rear transverse link bushing psyber_0ptix Private 'For Sale' Classifieds 0 02-18-2006 10:30 AM
STi Transverse link bushings or Whiteline ALK or Perrin PSRS? downeyer Brakes, Steering & Suspension 10 04-27-2004 11:38 AM
SPT Transverse Link Bushings -- Already on STi? ToddStratton Brakes, Steering & Suspension 3 04-06-2004 02:31 AM
Anybody have a pic of the v8 rear transverse link bushing? BIGSKYWRX Brakes, Steering & Suspension 0 01-16-2004 10:21 PM
SPT Transverse link bushings = less steering play? spanyo Brakes, Steering & Suspension 10 10-23-2002 07:20 PM
