Old 02-28-2001, 05:49 AM   #1
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Question Autodown Passenger Window?
Has anyone tried to convert the passenger window to "autodown"? I am wondering if the switch is the thing that makes it autodown? It seems like the switch has a circuit breaker like thing in it that makes it work the way it does. Has anyone tried to put a drivers side switch onto the passenger side to see if it will autodown?
subarumantoo is offline
Old 02-28-2001, 05:57 AM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Thumbs up
as long as it takes that window to come down i would do that too
bratmantlz is offline
Old 02-28-2001, 06:19 AM   #3
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
The switch for the driver side window is a three-pole switch, if you push it down half way it makes one connection, if you pull it up it makes a second connection, and if you push it down all the way it makes a third connection. that third circuit tells the window controller to roll it down all the way.
It the driver side and passenger side controllers are seperate (ex: the passenger side window is connected directly to the switch, or has a second box) it may be possible to replace all it's workings with a set from the driver window, but this may disable the switch on the passenger side. more likely though, is there is a computer that controls both windows and all the switches, in which case this probably cannot be done.
Safir is offline
Old 02-28-2001, 07:42 AM   #4
ImprezedRS
Member#: 2771
2003 BMW Z4
Post
My driver and passneger are auto down and up with the window moudule that i got for my alarm system.
ImprezedRS is offline
HTML code is On
Passenger window doesn't roll up, other windows work both ways. Phylomatic Electrical & Lighting 7 06-10-2008 02:22 AM
Passenger Window not working beethoven Normally Aspirated Powertrain 7 02-18-2002 04:39 PM
Passenger window on Coupe RS problems? AWDBOY Interior & Exterior Modification 12 11-30-2001 12:19 AM
some @$$hole broke my rear passenger window! Necromancer Bay Area Impreza Club Forum -- BAIC 8 05-29-2001 02:14 AM
slow passenger window slapey General Forum Archive 6 05-23-2000 04:49 AM
