Old 03-04-2004, 06:46 PM   #1
PURE EPI
Member Sales Rating: (2)
Member#: 2642
Default APS cast intercooler duct
Just got finished installing:
I can truly recommend this upgrade. The power delivery is much more linear. This should make the flow dynamics much better overall. This is a must for you folks still running a TMIC and have made power upgrades. I'm a big fan of smoothness...and this little baby delivers. The part is indeed coated to avoid heat soak.
Christian
PURE EPI is offline   Reply With Quote
Old 03-06-2004, 12:36 PM   #2
AlboWRX
Member Sales Rating: (5)
Member#: 37719
2003 WRX
How much is the kit and where did you picked it up at? Thanks
AlboWRX is offline   Reply With Quote
Old 03-06-2004, 09:27 PM   #3
PURE EPI
Member#: 2642
Sorry to take so long getting back to you.
The kit is available from multiple vendors. I got one from the local tuner shop here. You can get it from ISR http://www.isrperformance.com/
the kit is very resonably priced. Some of the guys here talk of the prodrive intercooler hose which, to me , looks no more than the standard Samco hose. This is cast aluminum and WILL NOT split. the flow is so much better.
Old 03-07-2004, 03:57 AM   #4
AlboWRX
Member#: 37719
2003 WRX
thanks. Can this be used with stock intercooler or upgraded APS one?
Old 03-07-2004, 11:54 AM   #5
PURE EPI
Member#: 2642
If you follow the link that ISR provides for the additional info via APS, they tell you that you need model CCD/01 for the APS top mount IC. The stock one is #CCD .
Old 05-21-2004, 02:39 PM   #6
makofoto
Member Sales Rating: (1)
Member#: 25243
2006 Legacy Outback
I used mine with a JDM STI IC ... mine was STI manifold RED
makofoto is offline   Reply With Quote
Old 05-24-2004, 03:59 PM   #7
jlevy
Member#: 15696
2015 WRX 6 speed
I've got the cast y-pipe on my car. It's a nice piece and I have only one complaint. No effort was made on the inlet of the Y to make a smooth transition from the silicone elbow piece. You can port it pretty easily, but it looks like a bit of a bottleneck IMO.
I can't confirm any difference in power since I installed several other items at the same time.
Here's a pic of the inlet where I've already taken the sharp edge off.
http://pg.photos.yahoo.com/ph/sjlevy...8c.jpg&.src=ph
Here's what mine currently looks like (smoothed and lightly ported) and it helps to see where the big silicone elbow dumps into a small aluminum entrance. http://pg.photos.yahoo.com/ph/sjlevy...57.jpg&.src=ph
-JL
edit to update links
jlevy is offline   Reply With Quote
Old 10-19-2004, 12:57 AM   #8
markadopolus
Member Sales Rating: (37)
Member#: 69586
I think APS discontinued the production of this part. at least thats what brainstorm performance says.
markadopolus is offline   Reply With Quote
Old 10-24-2004, 11:05 AM   #9
King Of Imports
Vendor
Vendor Sales Rating: (2)
Member#: 64590
Some new GDB STis in Japan are coming with a revamped intercooler and Y pipe to reduce the turbulence in the air flow as it flows through the Y pipe and into the intercooler. You will know when these become available here because there are two humps on top of the Intercooler which also increase its area and reduce the amount of room between the Intercooler and the firewall. No idea yet whether this will fit on USDM STis or WRXs with Strut bars.
If APS stopped making it, maybe we can persuade them to make it again because the OEM part will always be more expensive. The Y Pipe out of Japan that we saw is a 1 piece rather than 2. Forgive this post if this subject has already been discussed.
King Of Imports is offline   Reply With Quote
Old 10-24-2004, 01:08 PM   #10
PURE EPI
Member#: 2642
I don't think it had. I know that because of changing exchange rates between US and Australia, things have gotten more exprensive. Even if we got them to make it again, I don'tknow what the cost would be. Might be equal or close to OEM.
3" silicone hose for an APS cast compressor duct joebud Private 'Wanted' Classifieds 2 07-13-2008 11:27 AM
APS Cast Turbo Outlet Duct MisterX Private 'For Sale' Classifieds 2 06-04-2004 07:50 PM
APS intercooler ducting PURE EPI Mid Atlantic Impreza Club -- MAIC 12 05-21-2004 02:38 PM
APS Cast Compressor Discharge Duct - Stock IC question rich22 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-28-2004 03:23 PM
APS cast intercooler pipe and stock intercooler LiquidForce Private 'For Sale' Classifieds 7 11-10-2003 01:04 AM
