Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-04-2004, 11:45 PM   #1
jwrx
Member#: 20084
2002 300 WHP WRX
@ sea level
Default Just Moved - Boost Question?... Need Facts ONLY
So I just moved to the midwest and am aware of the altitude - I moved from FL. where my car put 300 to the wheels. Mods:
VF30
Turbo Back, Up pipe, pulleys BOV 50/50
Injectors, Rails, Pump
Top Mount MRT...
ECUTEK - Blah Blah
Thats all thats relevent....
My car surges bad in WOP 4th and 5th a little in 3rd.... Its running 11.1 AF.... IDC at 70% or so (This is Tampa numbers)... Dyno graphed....
So I am aware that with the altitude in Denver, the motor is seeing more boost - Thus the timing is being yanked at peak boost levels... By the way it is peaking here @1.25 bar (High I know)... Tuned to only 1.15 in FL....
Is all this right (My thoughts) - I need somebody to confirm, also if anybody in denver has Delta Dash - Lets talk - I have the laptop, even one up for a trade on a license share.
Thanks
Jeff
jwrx is offline   Reply With Quote
Old 03-05-2004, 01:37 PM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Check out what I have been working on here
http://forums.nasioc.com/forums/show...hreadid=512707
It is not entirely accurate yet and I am still working on it but it will give you an idea of some of the trends you are looking at.
no-coast-punk is offline   Reply With Quote
Old 03-05-2004, 08:39 PM   #3
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Jeff -
Atmospheric pressure here is around 80-85% of sea level. Given that your IDCs were ~70% at sea level, fuel is definately not going to be your problem.
I don't have the compressor map for the VF 30, but 1.25 bar at this altitude may be pushing a pressure ratio that is outside that turbo's peak efficiency. That turbo is working a good deal harder to push 1.25 bar up here that is is pushing 1.15 bar at sea level.
Check out :
http://forums.scoobytech.net/phpBB2/viewforum.php?f=3
If you dig around the forum, I think you'll find the compressor map for the VF30.
Good luck with the problem. You may have to get a re-map for your mods & higher altitude.
Diz is offline   Reply With Quote
Old 03-06-2004, 12:12 AM   #4
jwrx
Member#: 20084
2002 300 WHP WRX
@ sea level
Thanks for the input - I am going to buy Delta dash and get a 2nd map from the guys in Tampa (let them give it a shot) and go from there - I will post my results!.
Thanks Again
just moved to cali, advice needed please txwes Southern California Impreza Club Forum -- SCIC 34 12-01-2005 03:59 PM
I just installed a boost gauge and I have a boost question... Hokie-wrx wagon General Community 12 08-28-2005 01:58 PM
Just moved to WA... Need some info about Suby dealers here SubyWRXSti North West Impreza Club Forum -- NWIC 7 01-08-2005 10:58 PM
just moved... need Bedroom set... italsupra10 Mid West Subaru Owners Club Forum -- MWSOC 0 08-15-2003 05:49 PM
