Old 02-27-2001, 07:36 AM   #1
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Post Will I encounter problems if I take off the AC belt from the underpulley?
It's too cold to use the AC anyway. I thought maybe if I take off the AC belt, I'd be able to send more power to where it needs it most - the engine. After all, that's what the Unorthodox pulley does, send less crank RPMs to the alternator and AC and more towards the drive train(or is it engine?).
I'm no mechanic so please go easy on the "you're soooo stupid!" comments. However, "you're crazy" is acceptable.
Snoopy is offline
Old 02-27-2001, 07:52 AM   #2
cvalle-sd
Member#: 420
2001 Cr-V
Post
If the AC compressor is the only thing on that belt - go ahead. But make sure you're not d/cing the power stering pump, too. I gotta take a look to make sure.
cvalle-sd is offline
Old 02-27-2001, 08:07 AM   #3
Frank
Member#: 3791
Post
I'd be interested in finding out if any gains would be safely had from this, i never use the A/C anyway. Please PM me if you find out any additional info.
~Frank
Frank is offline
Old 02-27-2001, 08:14 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I don't see why not, but I think we're supposed to run the AC every week or month for about 10 minutes even in cold weather so that the AC can be lubricated during off-season.
tmat3 is offline
Old 02-27-2001, 08:25 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
tmat3 has a good point (although I must confess I have never remembered to do that with any car I've driven ). The other thing I would add is that when the A/C is not on, the pulley is probably just free-wheeling. I know that's the way my '89 Mustang is set up - the compressor has a clutch that disengages when the A/C is off. If Ford could figure out how to do that in '89, I would imagine Subaru does this now.
So, the A/C is probably just an idler pulley essentially. Does anyone know if this is correct?
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is offline
Old 02-27-2001, 09:51 AM   #6
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Post
I live in Colorado--I've never used AC on any of my cars. Even if it's hot I odn't--Slows my car down. I've got the N1 UD Pulley and I NEVER thought about this. I'm curious now!!! I will pull it off tonite(weather providing).
Brahmzy is offline
Old 02-27-2001, 09:55 AM   #7
Danno
Member#: 3013
2002 WRX Sedan
Mithril
Exclamation
Remember that the A/C engages when you turn on the defroster, to help dry out the air and defog the windows. If you disconnect the compressor drive belt your defogger may not work as well.
Dan
Danno is offline
Old 02-27-2001, 10:15 AM   #8
Primm Motorsports
Vendor
Member#: 2098
Post
Danno: That is only true of the Legacy models, our RS's do not do this.
Dante
Primm Motorsports is offline
Old 02-27-2001, 11:19 AM   #9
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Post
I didn't know the Legacy's did. I thought it was a Subaru trait for the a/c-comp not to come on during defrost.
donjuan is offline
Old 02-27-2001, 11:28 AM   #10
kaos200
Member#: 2692
Post
Our a/c only freewheels when not on so I wouldn't imagine a big gain in power if the belt was removed...
kaos200 is offline
Old 02-27-2001, 11:28 AM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I think the Outback and Forester also exhibit the auto-AC trick while using defrost. Imprezas don't, at least the RS doesn't.
-Colin
ColinL is offline
Old 02-27-2001, 02:02 PM   #12
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Post
The A/C just free wheels when off. You would find more gains by the jet propulsion of a good fart then you would by removing that belt.
DonA is offline
Old 02-27-2001, 02:28 PM   #13
Danno
Member#: 3013
2002 WRX Sedan
Mithril
Post
One other thing I've made an educated guess about, that may also be Legacy-specific: I've noticed that when I'm cruising down the highway with the A/C on, and then put the accelerator all the way to the floor to pass, the A/C suddenly blows warm air, then cools back down when I let off the gas. Unless something weird is wrong with my car, Subaru has a tricky way of freewheeling the A/C compressor when maximum power is needed. Has anybody else noticed this?
Dan
Danno is offline
Old 02-27-2001, 02:35 PM   #14
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Disabling the AC compressor at WOT is a feature shared among all modern Subarus and it is even documented in the owner's manual, at least mine.
ColinL is offline
Old 02-27-2001, 02:40 PM   #15
Danno
Member#: 3013
2002 WRX Sedan
Mithril
Post
Well, I might not be able to read, but at least I'm not hallucinating! Thanks, Colin!
Dan
Danno is offline
Old 02-27-2001, 02:55 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
hmmm colin... dunno about that you would feel it kick back in
Jaxx is offline
HTML code is On
Broke the ac belt tensioner, but ac belt is still tight. Am I safe? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-12-2009 04:18 PM
Will I save cash If I import a 2nd hand STI from the U.S into Canada? goldwave84 General Community 13 06-26-2007 06:59 AM
Where is belt tensioner for the AC belt Stover954rr Service & Maintenance 3 06-17-2006 02:15 PM
Will it look good if I only bought the side skirts from the subaru oem body kit FlipWRX Interior & Exterior Modification 4 10-10-2002 03:39 PM
Take off the AC belt.. jacktam1 Technical Forum Archive 4 09-22-2000 07:31 AM
