Old 12-11-2000, 07:08 AM   #1
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Question need help diagnosing a lurching problem
Over the last few days my MY99 RS has developed some kind of hiccup. When I'm accelerating hard in second or third gear the car will hesitate randomly. It feels exactly like the fuel starvation problem we some times encounter while cornering, except that I'm traveling in a straight line. I was thinking that it could be a number of things, but I could always use a few more oppinions.
The car has a little over 40K miles on it. I haven't replaced the fuel filter yet or the spark plugs, so they might help. The other thing I thought it might be was the MAF. The last time I cleaned and re-oiled my K&N panel filter I don't think it was totally dry before I reinstalled it and had to go. So could it be that some of the filter oil has gotten onto the hot film and is screwing things up? I remember a post a long time ago that mentioned using some electronics cleaner that came in a spray can to clean the MAF wire. Does anyone remember what that stuff is? (I'll try a search)
If I'm going to replace the fuel filter I'm going to have to de-pressurize the fuel rails, right? How do I go about doing that, any tips?
Thanks
Travis R is offline
Old 12-11-2000, 09:13 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Definitely replace the fuel filter.
Quick way to depressurize the fuel system:
1. disconnect battery
2. unscrew gas cap (woosh)
The Haynes manual outlines like 2-3 other steps but I find these two to be sufficient.
Shame on you on the fuel filter-- that's a 30k maintenance item I believe. A very dirty one could certainly cause the problem you have.
The plugs wouldn't, but I guarantee you will notice a difference in idle quality and probably performance in replacing them. I like Bosch platinum-- easy to find in the stock heat range, cheap and effective. I also like ND and NGK copper but they're not as easy to find in stock, at least at stores near me.
Good luck.
ColinL is offline
Old 12-12-2000, 07:43 AM   #3
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Exclamation
The fuel filter makes the car feel entirely different. Also re-set your ecu. I haven't done my plugs yet (32k miles) But I will soon. Definitly do the filter, its 26 bucks from the dealership, Subaruparts.com or Teagues might have it for cheaper. It only takes 10 minutes to do, the toughest part is removing the fuel lines.
STiShawn is offline
HTML code is On
HELP HELP HELP Need help diagnosing a clutch problem.... redoktober_99 Tri-State Area Forum 9 02-06-2007 10:28 PM
Need help diagnosing several electrical problems probably connected... The Modaholic Electrical & Lighting 2 12-28-2004 12:50 AM
Hey guys, need help diagnosing a problem SiOrange New England Impreza Club Forum -- NESIC 19 12-15-2004 05:48 PM
need help diagnosing problem... Enigma76 Car Audio, Video & Security 4 05-24-2004 01:08 AM
Need help diagnosing an engine problem Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 10 04-07-2003 02:17 PM
