Old 03-05-2004, 05:03 PM   #1
SinhCredible
Member#: 33517
2005 FXT(i)
CGM
Default Whats involved in a 30k mile service.
What did you guys do and what did you guys let the the dealer do?
SinhCredible is offline   Reply With Quote
Old 03-05-2004, 05:13 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Dealer hasn't touched my car since I bought it. I've done all maintenance. It's not difficult. . just takes some time.
Calvin
cnk is offline   Reply With Quote
Old 03-05-2004, 05:23 PM   #3
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
I think it is:
Tire rotation
Oil and oil filter change
air filter change
fuel filter change
coolant flush
brake fluid change
inspect all fluids
check and/or tighten all belts etc.
There may be a couple more little things, but this is what I did myself.
K
rankink is offline   Reply With Quote
Old 03-05-2004, 08:59 PM   #4
inurb
Member#: 53671
2001 GM6
The four door hater
Murray did my 30K checkup. It consisted of this
Oil Change
Oil Filter Change
Air Filter Change
Fuel Filter Change
Front & Rear Differential Change
Sparkplug Change
Radiator Coolant Change
Then we ate pizza.
inurb is offline   Reply With Quote
Old 03-05-2004, 09:39 PM   #5
me poet
Member#: 54956
2001 Forester L SW
Green
We had our Forester done by the dealer. First they inspected everything (there was about thirty items on the check list). I have the ticket in the car, but the car is still in the body shop. This is what I can remember:
changed oil and filter
rotated tires
flushed fuel line and injectors
added a can of something that cost $43.00
flushed radiator and replaced coolant
replaced air filter
replaced fuel filter
flushed transmission and replaced fluid
replaced transmission filter
replaced belts
replaced spark plugs
There was more, but I can't remember the rest. T'was not cheap.
me poet is offline   Reply With Quote
Old 03-29-2004, 03:33 PM   #6
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Space Gray with Coral Red
Subaru.com calls for:
Inspect Steering and suspension
Inspect Clutch operation
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Brake linings and drums
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Replace Brake fluid
Inspect Automatic transmission fluid
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Replace Spark plugs
Replace Air cleaner element
Recommended Performance Replace fuel filter and inspect fuel system, hoses and connections
Perform Replace engine coolant and inspect cooling system, hoses and connections
Replace Engine oil filter
Replace Engine oil
Inspect Camshaft drive belt
Inspect Drive belt(s) [Except camshaft]
Of that, I would do my own oil and filter, and I have a K&N (and I'll rotate the tires which strangely the website does not list).
That leaves me with needing to replace - spark plugs, coolant, brake fluid, and recommendation of fuel filter (and then all those "inspections"
I am hoping the dealer will "adjust" the 30k mile service cost to reflect only what I want and need done. Is the fuel filter an overkill?
Jeff
ezatnova is offline   Reply With Quote
Old 03-30-2004, 07:07 PM   #7
jmolaver
Member#: 19130
'01 TTE Miata
www.awesom-oracing.com
Actually just did most of this today, and while I've done some minor stuff before I was a little intimidated by it...
Fuel Filter - very easy to do - hurt my thumbs wiggling off the fuel lines, but probably only took 10-15 minutes.
Oil / Oil filter / Air filter - simple as ever..
Transmission / Gear Oil - just like an oil change. BUT I highly recommend you get a flexible and relatively thin funnel for this, unless you want to take the intercooler off (I tried and it wasn't fun)..
I'm going to do the brake fluid change out tomorrow, but probably bring it to a place to do the coolant flush, anti-freeze is nasty...
All in all it was fairly easy maintenence, just make sure you have all the tools / parts / etc you need before you start...
jmolaver is offline   Reply With Quote
Old 03-30-2004, 08:46 PM   #8
ezatnova
Member#: 10877
2007 BMW 335 Coupe
While I wouldn't be thrilled to do the coolant or brake fluid, it's actually the spark plugs that I'm dreading. It doesn't sound like you replaced them, but I think they would be one of the more critical maintenance items.
If you ever have to take the intercooler off to make something easier, don't sweat that! I've had it off 4 or 5 times to fool with my BOV and now I can literally have it off in 2 minutes and back on in 5.
Old 03-31-2004, 02:02 PM   #9
Julian
Member#: 1182
MY00 RS
BRP
Julian is offline   Reply With Quote
Old 03-31-2004, 02:40 PM   #10
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I've done everything myself, except the brake fluid so far. You should only have to do the spark plugs at 60k miles. That's the only thing i'm going to have the dealer do when i get to that point. I just took care of 1 item every when when i got close to 30k and i'm almost done with everything now (except the brake fluid). The coolant probably took the longest (about 2 hours since i'd never done it before.) Brake fluid shouldn't take too long either, but i'm going to be installing some SS brake lines at the same time.
Old 03-31-2004, 11:02 PM   #11
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Coolant is no big deal; I've done it lots of times. Just don't drink it
Mike Wevrick is offline   Reply With Quote
Old 04-06-2004, 12:43 PM   #12
SilverJA
Member#: 11544
93 Legacy L
01 RS; 02 WRX; 08 STi
Question
I know this is probably a dumb question, but does it matter what coolant I use or where I get it? I have a friend that has a VW and he says he has to use coolant from the dealer or it will void his warranty or some crap like that, sounds rediculous to me.
SilverJA is offline   Reply With Quote
Old 04-06-2004, 01:09 PM   #13
bheinz57
Member#: 37870
2012 ISM WRX
'07 FXT Sports
Only use a coolant with no silicates-that is what Subaru says. I went to the dealer to buy a gallon of genuine Subaru coolant. It was $12 and that sucked, but I don't feel like going to a parts store and reading all the ingredients on other makes either. Brian
bheinz57 is offline   Reply With Quote
Old 04-06-2004, 11:02 PM   #14
SilverJA
Member#: 11544
93 Legacy L
Ouch, that does suck. Thanks for the info though!
Old 04-08-2004, 03:09 AM   #15
wrx112
Member#: 35048
how do you do the coolant how you know if it is completly flushed out? anyone with a step by step procedure. also for the rear diff do you flush that out with cheap oil? Also what oild should you use for the rear diff or transmission fluid? LMK please thanx
mike
wrx112 is offline   Reply With Quote
Old 04-08-2004, 09:10 AM   #16
Psydotek
Member#: 44168
2003 Yellow WRX
I don't think you can completely "flush out" the old coolant without a shop or special machine. But by simply draining the radiator and refilling it once a year or every 30k miles should keep the fluid cycling and fresh enough that you shouldn't have to do a complete flush...
[then there's all the other issues with complete flushes that involve removing helpful deposits, causing premature leakage, $$$...]
Ted Kazinsk... er... Unabombers Coolant FAQ
Scooby Mods Rear Differential Fluid Change
Scooby Mods Transmission Fluid Change
You're welcome.
[FWIW, i've got Mobil 1 Synthetic 75w-90 in the Rear Diff and NEO Synthetics HD 75w-90 in Transmission] [fluid doesn't solve shifting problems, proper shifting solves shifting problems, and if it doesn't, your transmission has problems...]
Old 04-18-2004, 08:16 AM   #17
BlackEye
Member#: 36203
2003 WRX
Platinum Silver Met.
Default Plugs..
The spark plugs are not that big of a deal. Not hard at all. Just have some patience and a good set of ratchets/extensions. I removed the intake assembly and washer reservoir assembly to do it.
R.
BlackEye is offline   Reply With Quote
Old 04-22-2004, 03:24 PM   #18
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Turbo-ling cars, my manual and CD says 60k for the plugs.
I'm changing them anyways at 30k just because I want to see what they look like at 30; plus they might be a little easier to break loose at 30 than at 60k. Other than a little lighter wallet and maybe a skinned knuckle, it won't hurt to do so early.
WRX03 is offline   Reply With Quote
Shop forgot to put coolant in my car after 30k mile service.. smash Service & Maintenance 21 04-17-2009 10:04 AM
What's involved in the 45,000 mile. or close, check up? jonnysubby Service & Maintenance 1 08-29-2005 10:25 PM
What exactly is involved in the 30k mile service? Jard Mid Atlantic Impreza Club -- MAIC 5 11-09-2004 09:52 AM
30k mile service, what do i need to do? ImprezedRS Normally Aspirated Powertrain 2 06-14-2001 07:26 AM
30k miles service- what should I replace the tranny fluid with? remarcable Normally Aspirated Powertrain 1 04-24-2001 02:29 PM
