Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 03-05-2004, 05:36 PM   #1
2.2gotboost
Member#: 22860
Default Does anyone know if there is a lightened flywheel that weighs between 17-20 lbs?
I am looking for a flywheel that is not less than 17 lbs. Excedy, Fidanza both are less than 15. Anybody know of one that is a little heavier? Thanks John
2.2gotboost is offline   Reply With Quote
Old 03-09-2004, 11:02 AM   #2
racinready300ex
Member#: 21953
I'm looking for the same thing, but I've yet to find anything. I don't think one exists
racinready300ex is offline   Reply With Quote
Old 03-09-2004, 11:29 AM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
STi? The Fidanza is too light but the Exedy should be fine.
mbiker97 is offline   Reply With Quote
Old 03-09-2004, 11:33 AM   #4
Safir
Member#: 3873
. Paradise is
like Disney with hookers
if you only want to loose a few pounds like that look for a competent machine shop to remove excess material from your stock flywheel
Safir is offline   Reply With Quote
Old 03-09-2004, 06:33 PM   #5
2.2gotboost
Member#: 22860
I have been told by others that a lightened flywheel is a bad idea because of the mountainous region in which I live. ACT has the heaviest aftermarket flywheel I can find. Excedy and Fidanza are both real close in weight (12Lbs.). You will be surprised how many vendors don't tell you the weight of these flywheels.
The machine shop thing I have already thought of, but that is just it finding a machine shop that can machine it and maintain the balance.
At this point I am going to resurface the stocker and put in the new clutch. John
Old 03-09-2004, 07:08 PM   #6
PeterJ
Member#: 14727
2002 impreza RS
So what is the actual weight of the ACT [and for what model car]?
Im thinking of having a stock flywheel lightened... A mechanic at a nearby dealer gave me a flywheel out of the trash, but I have no idea what it belongs too.
As far as balancing, if the shop is an automotive machine shop and they resurface flywheels and work on pistons and rods and such, then they will definately have a balancing machine, or send it to someone who does.
PeterJ is offline   Reply With Quote
Old 03-09-2004, 07:41 PM   #7
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
What are the negatives of a lightweight flywheel for mountain driving? Just that the revs climb and fall to fast? I'll be looking to get a new flywheel when my clutch dies.
BAC5.2 is offline   Reply With Quote
Old 03-09-2004, 08:23 PM   #8
2.2gotboost
Member#: 22860
ACT for WRX weighs around 14Lbs.
I was told the drawback was having to rev the car to like 5000 rpm's to take off. It seriously affected the driveabilty so bad he changed it back to stock. I am not going to risk it for a little more performance. Just got to get rid of that crappy stock clutch. John
Old 03-22-2004, 06:54 AM   #9
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
My new Act Streetlite fw did not significantly degrade drivability--the quicker reving is especially nice for mountain driving. Mine can be lugged off the line at low rpm's, even in 2nd gear. This is w/ a taller than stock 1st and a VF22.
The big downside is more deceleration NVH due, in part, to my hardened STi tranny and motor mounts and shifter bushings.
Subahaulic is offline   Reply With Quote
Old 03-24-2004, 01:28 AM   #10
chileewili
Member#: 13080
2002 wrx waggy
The downsides of running a lighter flywheel is that you'll probably lose a mpg or two running highway, and that you'll run up and down the rev's quicker (which can be a good thing or a bad thing depending on perspective) -but isn't that what you're going for with a lightened flywheel? the quicker rev's? You'll also be likely to have a slightly rougher idle, that's why many manufacturers use a dual-mass flywheel.
chileewili is offline   Reply With Quote
Old 03-24-2004, 10:55 AM   #11
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Too light and you remove mass from the crank and rotating parts that will no longer absorb harmonic forces and you will throw misfire codes, so lighter isn't always better.
cdvma is offline   Reply With Quote
Old 03-24-2004, 06:13 PM   #12
mbtoloczko
Member#: 36625
2006 Evolution 9
425 ft-lbs / 505 whp
Originally posted by 2.2gotboost
.... Excedy and Fidanza are both real close in weight (12Lbs.)...
My Exedy lightweight flywheel weighs 13.5 lbs. I weighed it myself.
mbtoloczko is offline   Reply With Quote
Anyone know if there is a local place that makes/repairs silicon hose? DickWRX Mid West Subaru Owners Club Forum -- MWSOC 5 09-01-2006 03:13 AM
Does anyone know if there is a company that... carguy19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-15-2004 10:28 AM
does anyone know if there is an actuall logo for the boxer motor ? Maxtastic Bay Area Impreza Club Forum -- BAIC 4 09-16-2002 11:33 AM
Does anyone know if there is a LATCH retro kit for the 99 Forester? mooney Forester Forum 1 09-11-2002 10:01 PM
does anybodu know if there is a grill out there..... SubyRacer Interior & Exterior Modification 7 12-04-2000 10:56 PM
