Old 03-05-2004, 11:36 PM   #1
DrBuzzad
Member#: 1345
2005 Legacy
Atlantic Blue
Default Can anyone point me in the right direction re:metalwork??
I have a design for an impact weapon that I'd like to test and hopefully mass produce.
I know nothing about metal...only that it's hard and sometimes shiny. How/where do I get the prototype made and then how would others be made if I wanted to mass produce?
The design is for a solid piece of stainless steel and the shaft of it would preferable have an octagon shape so I have a hard time picturing something like this done by hand.
Thanks in advance for any advice and any shove in the right direction.
-Matt
DrBuzzad is offline   Reply With Quote
Old 03-05-2004, 11:39 PM   #2
Hunter S. Thompson
Member#: 42185
I sculp in [Artist] metals mostly steel. Proficient with oxy/accetylene, MIG, TIG, Plasma cutting, Forging, Foundry.
But I have no earthly idea of what your talking about, nor do I have any suggestions of where you should go to for Prototypes.
Good Luck , I think.
Hunter S. Thompson is offline   Reply With Quote
Old 03-05-2004, 11:45 PM   #3
DrBuzzad
Member#: 1345
2005 Legacy
Atlantic Blue
if I wanted to have a solid steel pair of sais custom made for instance, where would I go?
Thanks.
Old 03-05-2004, 11:47 PM   #4
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
I would assume one of those CAD operated machines (mill, Lathe??) Could do the trick.
Old 03-05-2004, 11:47 PM   #5
Hunter S. Thompson
Member#: 42185
You would have to cast it, and I have no idea where you could custom cast steel....
Sorry, H.S.T.
Old 03-06-2004, 01:24 AM   #6
2Stroke
Member#: 36712
2003 WRX Wagon
You can purchase hot rolled or stainless steel hex stock in sizes up to about a few inches in diameter iirc. This can then be cut to length and machined, not necessarily in that order, but probably.
Look in the yellow pages under "machine shops" to find the folks who might make it. Also check out "rapid prototyping". It might be much cheaper to build a non-functional demonstrator this way.
No matter where you go for help making whatever this is, you'll need a dimensioned drawing, or at least a sketch. Rapid prototyping requires a 3-D cad file. The drawing/CAD file is what you use to communicate the design to others.
If you can't create one yourself, the first thing to do is find someone who isn't CAD challenged and get them to draw this thing. Then you can send out the drawing for bids, and you'll get an idea of the cost. Many potential products come to a grinding halt right after that.
2Stroke is offline   Reply With Quote
Old 03-06-2004, 01:39 AM   #7
Protege Menace
Member#: 41950
faq u rug
WHat exactly are you making?
im building the FSAE car from scratch and so far have made brake rotors, enlinks, bearing housings, diff housing, rim washer thigns, and many other car partys all on a lathe.
you can do anything wtih them and maybe with the help of a mill.
Protege Menace is offline   Reply With Quote
Can someone point me in the right direction? Lower Control Arm Bushing. Rosie684 Brakes, Steering & Suspension 4 04-24-2010 11:47 PM
can someone point me in the right direction scrappydoo7 Newbies & FAQs 5 04-17-2010 09:29 AM
can someone please point me in the right direction.. Calikid Newbies & FAQs 6 03-11-2010 07:12 PM
I need vector outline of old gen Impreza. Can anyone point me in the right direction? Sean Member's Car Gallery 17 01-20-2005 12:28 PM
can someone point me in the right direction for a headlight bulb? Handsdown Interior & Exterior Modification 2 09-19-2004 09:39 PM
