Old 03-06-2004, 12:31 AM   #1
loudog800
Member#: 19683
2002 Subaru
WRX
Default fuel filter replacement
Can anyone give me the procedure for replacing the fuel filter in '02 WRX? Quick search showed nothing.
loudog800 is offline   Reply With Quote
Old 03-06-2004, 12:44 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
1. pull the fuel pump relay and crank the engine to decompress the fuel system OR leave the car overnight to let the fuel system decompress
2. remove the rubber lines going to the fuel filter and remove the filter
3. You may need to move the rubber wrapping around the stock filter over to the replacement filter.
4. Then just reverse the process for install
You may want to have some rags around just in case there is still some fuel in the lines and they leak. Also, don't turn the filter upside-down as there is fuel inside it.
Calvin
cnk is offline   Reply With Quote
Old 03-06-2004, 12:11 PM   #3
loudog800
Member#: 19683
2002 Subaru
WRX
So you're saying I can just let my car sit over night and then replace the filter?
Old 03-06-2004, 01:15 PM   #4
cnk
Member#: 10757
Yes.
Calvin
Old 03-06-2004, 11:26 PM   #5
ANSER
Member#: 11383
2002 Impreza WRX WRB
2011 Outback 2.5i Ltd
There is a well written text on scooby mods.com>forums>modifications>Imprezawrx 02-04>performance>fuel filter removal and install--it helped me a lot-I have pm'ed you a cut and paste version of the text-Good luck and Happy filtering !
ANSER is offline   Reply With Quote
fuel filter replacement vtownrida Service & Maintenance 11 12-18-2009 08:35 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
Fuel filter replacement Shifter Service & Maintenance 3 08-31-2003 06:16 AM
wrx fuel filter replacement phillywrx Service & Maintenance 9 10-10-2002 12:12 PM
Fuel Filter Replacement? Ryan24 Service & Maintenance 8 08-07-2002 10:59 AM
