Old 03-06-2004, 04:25 PM   #1
loudog800
Member#: 19683
2002 Subaru
WRX
Default oily air filter
I just got my oil changed at 29000 miles. The mechanic showed me the air filter and it had a lot of oily dirt on the filter. He said it was "air filter blow by" and I should get it checked at the dealer. Is this normal? I know it is scheduled to be changed at 30K, but is this something to get checked out or has anyone else seen this?
BS
loudog800 is offline   Reply With Quote
Old 03-06-2004, 05:19 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Laugh it off....'air filter blow by'.......
THAT'S a GOOD one!!!!
Make sure the monkey put the airbox cover back on right....there are 2 tabs on the cover, inboard, that have to be hooked back into the lower part of the box.....it can be a PITA...but it is possible to do without taking anything apart.
Old 03-06-2004, 11:21 PM   #3
loudog800
Member#: 19683
2002 Subaru
WRX
So you think it is normal for a filter driven for 29k miles? He said it would have been normal if it weren't so oily.
Thanks
BS
Old 03-07-2004, 12:51 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
Well....I had an almost brand new, stock, airfilter that I took out of the car and set it on a cardboard box overnight...and it left a pretty good oil stain on the box....so that leads me to believe that the stock filter is oiled at least a little form the factory....so...
Don't worry about it....change it and clean the inside of the airbox out and be
Old 03-07-2004, 12:52 PM   #5
Hayes
Member#: 11808
The OEM filter(Purolator) is an oiled filter as is the Purolator at your local auto parts store. A small amount of oil is from the crankcase ventalation system (ie PVC) and is considered normal. If however you have a great deal of oil like dripping then check the PVC valve ans associated hoses. Ed Hayes
Hayes is offline   Reply With Quote
Old 03-07-2004, 07:53 PM   #6
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
When i changed out my intercooler hoses, they had a light film of oil from blow-by. Sort of normal in a turbo car with a bit of power.
mtb_dude is offline   Reply With Quote
Oily air filter fugglybubbler Normally Aspirated Powertrain 5 04-27-2010 11:21 PM
Oily Drop In Air Filter ucsdmutt Engine Management & Tuning 9 02-25-2005 07:38 PM
Oily substance in air filter? digidelia Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-20-2003 11:45 PM
Oily residue in the air filter box? subysouth Normally Aspirated Powertrain 7 07-12-2001 05:02 PM
