#1 |
Member#: 19426
Vehicle:2002 WRX Black I luv the Ice Gnomes.... |
Let me describe the symptoms:
I get a chirpping sound when I'm in 1st or 2nd gear. It usually happens when I'm letting off the gas. Right when I take my foot off the gas I hear a "Chirp!". Like I will be slowly reving and then let up on the gas.. Chirp! Sometimes it happens even when I'm keeping it at a steady throttle, maybe rpms at 3k or 4k in 1st or 2nd gear, and I get the "Chirp" as if a belt slipped or something. I just noticed it last week. Any ideas? This is a 2002 WRX.
#2 |
Member#: 47597
Vehicle:1997 ///M3 '93 Impreza |
does it happen when you engage the clutch? if it does it could be a throw out bearing. But yes it could also be a belt. Did you check the tightness of all your belts?
#3 | |
Member#: 19426
What belt could it be? Not exactly sure which one... if I brought it to a garage or back to Subaru couls I just ask them to tighten all the belts? Thanks. |
#4 |
Member#: 47597
i dont think you can tighten belts persay. I think there just wear and replace items
#5 |
Member#: 17751
Vehicle:2002 WRX Wagon 944 Turbo track |
Like a bird chirp? If so, it maybe your exhaust hangers.
#6 |
Member#: 22738
I heard this sound and further inspecting its from the exhaust mounting. Nothing to worry about, just a sound to live with.
#7 |
Member#: 19426
The exhuast hangers? Really?
That would explain the randomness of the sound and its non-relation to reving, shifting or acceleration. I had no idea the exhaust hangers could make any noise in the first place... I guess I'll grease them up. |
#8 |
Member#: 40596
SCIC
Vehicle:03 WRX MBP |
YEP! Its the hangers. Also, you can check your filter box. If the box is attached correctly, the wind blowing it can cause the whistling sound or bird-like sound.
SOSOSOSOSOSOSOS........NEED HELP! ![]() |
#9 |
Member#: 19426
Cool. I got a urethane exhaust hanger from Kartboy.
#10 |
Member#: 20184
Vehicle:2002 Impreza WRX WRB |
I have a sound that sounds exactly like this, but it comes with a very slight hesitation. It makes a chirp, usually first or second gear, either right when I get off the gas or right when I step on it. It always sounds the same, just a tiny peep, but I'm pretty sure it's not an exhaust squeak because of the hesitation. Any ideas? loose belt? Thanks,
Andy |
#11 |
Member#: 19426
Thats sounds exactly like what I described. These guys swear its the hangers... I should be getting that urethane hanger today, so I'll let you know if that fixes it.
Either way, you and I have the exact same symptoms. |
#12 |
Member#: 20184
Hey Chewy - does yours hesitate when it happens? I don't think its hangers or anything because of the slight stutter in power (or deceleration for that matter) I can feel it happen, not just hear it...
#13 |
Member#: 26341
Vehicle:2002 WRX Wagon Silver |
This same thing is starting to happen to me. This morning I was in the midst of accelerating in 3rd. Between 3000 - 4000 RPM, I heard the squeak and felt a very momentary loss of power. I probably heard the squeak 5 times on my 15 minute drive to work.
#14 |
Member#: 20184
Thats when mine usually happend, accelerating through about 3600-3800. It seems to happen a lot some time and not at all others, very strange.
#15 | |
Member#: 19426
Still havent gotten my hangers yet. I will definitiely report back here when I put them on and we'll see if it helps. But I agree. Read my posts earlier. I'm very surprised that this is the hangers. Either way since kheti has the same problem, we'll all find a resolution some how. Because that squeak sucks ![]() |
#16 |
Member#: 20184
I'll be interested to hear if the hangers do anything, if so thats great. Otherwise I started noticing mine after I had the IC off, so I'm going to take it off again and see if I can find any problems there.
Hopefully we can get to the bottom of this, it's really bothering me!Last edited by aberg; 03-26-2004 at 01:28 PM. |
#17 |
Member#: 26341
I can understand the squeak coming from the hangers but not causing a power loss. The unpredicatability of this problem makes me feel the problem is electronic in nature, but the squeak would point to a mechanical one. Maybe a vacuum leak?
I'm happy to report yesterdays drive home from work and todays drive to work was absolutely problem free. |
#18 |
Member#: 20184
Mine is like that too, sometimes it doesn't do it at all, other times it's every 30 seconds. I can't figure out if it's weather related or what, but odd how it comes and goes. Or maybe I just don't notice it sometimes, that could be too...
#19 |
Member#: 19426
Ok, I put on the urethane exhaust hanger. Turns out we have two hangers... so I need to buy another one from Kartboy. Any rate...
I think this helped... I still get the chirp/squeak, but its not as loud. I'm fairly certain that this noise is coming from the hangers. Here is why: 1) It happens when you go over a bump sometimes 2) Sometimes when you take a corner realy hard you hear it 3) When the you let off the gas quick the jerk in the car sometimes causes the sound 4) "Sometimes" is the key word. I think because the hanger shifts and every time it shifts one way it will squeak. Does that make sense? Any rate I'll order another hanger and we'll see what happens. |
#20 |
Member#: 40596
SCIC
Its the Hangers fellas
I had days trying to figure it out and I decided to shove my face near my exhaust pipe when my girl was accelarating in neutral. It will produce the same affect when u pushing more rpms...that in turns moves the muffler in awkard manner causing it to chirp. The symptoms are very close....If its coming from your rear end, then most likely it will be that. ![]() |
#21 |
Member#: 19426
Update:
I now have two Kartboy urethane exhaust hangers on. The squeak is still there, but significantly less. Could this be because the weather is warmer? or is it the hangers? Can any moderators comment on this? -Chewy |
#22 |
Member#: 20184
My question is what would the exhaust hangers have to do with a hesitation or loss of power? Or is that just my imagination that I'm feeling a hesitation? Or is something else causing the hesitation and the squeak in the hangers is happening because of the hesitation? Thanks guys!
Andy |
#23 |
Member#: 26341
I think I may have found the source of my squeak. The other day when I turned my air conditioner for the first time this year (I'm normally a windows down kind of guy), I got the squeak and the hesitation because of the compressor.
This points to the accessory belt as the source of the squeak, but why would I get this occasional sound and feel when the A/C isn't on. Does the computer automatically kick the A/C compressor on every so often to keep the system lubricated? Another possibility is the electric fan kicking on, putting a strain on the electric system, causing the alternator to work hard and the belt to squeak. I know, this is a stretch. |
#24 |
Member#: 19426
From what I've noticed its not the sqeauk that causes the hesitation and loss in power ... its the hesitation that causes the squeak.
I think the gas pedal is a little touchy when you have it reved at 3000-4000 and pressed down half way.. somethimes a very minor change in the pressure on the throttle causes it to jerk or 'loose power'... I was thinking that jerk might cause the exhaust to twist causing the squeak... however I changed the hangers... so now what? Can you take a wrx to the deal and say "Tighten my belts"? This seems like it must be a semi-common problem since there are three of us (at least) talking about it. I could take a mechanic for a 5 minute ride at hear the squeak at least once. |
#25 |
Member#: 19426
This is definitely not getting any better.
The Sqeak is occuring multiple times on even short drives. I get the squeak almost always when I let off the gas. I'm debating taking it to Subaru. |
| Thread Tools | |
| Display Modes | |
| Cold Engine chirping/squeak on throttle lift | skoobywrx | Normally Aspirated Powertrain | 5 | 07-27-2008 08:26 PM |
| Stock STI: strange chirp/squeak sound... suspension? | tracks | Brakes, Steering & Suspension | 0 | 05-29-2006 01:56 AM |
| whine 2 tones loose belt? | 2.5RSMatt | Normally Aspirated Powertrain | 5 | 03-30-2004 12:17 AM |
| Weird chirp / squeak noise from exhaust on deceleration? | Rexxxx | Factory 2.0L Turbo Powertrain | 6 | 03-25-2004 04:47 AM |
| Loose belt or alternator on last leg? | grindMARC | Electrical & Lighting | 2 | 01-28-2004 11:05 PM |
