Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 03-06-2004, 11:13 PM   #1
Member#: 7140
2009 WRX
satin white pearl
Question loose spark plugs -- what could happen??
this question isn't about my wrx..in fact, it's in regard to a 1996 Ford F-150. today, i did a plug/plug wires/distributor replacement...in the process, i discovered that the number 2 plug was cross threaded, and the 3rd and 6th plugs were loose...in other words, i could unscrew the plug with my bare hand. a) what would a loose plug do to a car's drivability? b) when i replaced the cross threaded plug, the new plug was cross threaded as well. what i mean by this is that it wasn't fully seated onto the cylinder head...what will this do...if anything?
feedback welcome...
db97 is offline   Reply With Quote
Old 03-07-2004, 01:34 AM   #2
Member#: 47597
1997 ///M3
'93 Impreza
reduce compression and thats about it. Probly make it run at 100%.
Do you allways torque them down?
xxtwowheelfiendxx is offline   Reply With Quote
Loose spark plug - recurring problem? pgscanlan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-28-2009 06:44 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
Broken and Loose Spark Plug! erikkellison Service & Maintenance 2 10-14-2007 09:11 PM
Question about possible loose spark plugs? DreddRS25 Service & Maintenance 6 03-31-2005 12:02 PM
What could happen if you overfill the Engine Oil Shikamaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-23-2005 12:49 PM
