Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 03-07-2004, 10:20 AM   #1
alacrity024
Review Crew
Member#: 49476
Default Alternator Warning lights in my SVX (underdrive pulley)
hi all-
when the stock 2-piece crank pulley separated on my '92 SVX, i opted for a cheaper, one-piece lightweight, underdriven pulley to replace it.
Since doing so, i've been getting alternator warning lights at sort of odd intervals. near as i can figure, they start coming on when my revs are below ~2,000.. they also come on sometimes when the car goes over a bump. the second bit kind of confuses me.
the reason i mention the underdrive pulley is because it would make sense that the alternator isn't spinning quite as fast anymore, right? the warning lights never really stay on for very long.. they fade in and out. it seems like maybe the alternator is just barely getting enough "spin" but sometimes it dips a bit, like when the PS pump starts up?
some SVX guys have reported brighter headlights, louder stereo, etc. when running a fat wire between the negative terminal of the alternator and the negative terminal of the battery.. do you think this "mod" would free up a bit more juice and solve my problem? should i just abandon the underdrive?
thanks in advance, and mods feel free to move this if you think it would get more response in a different section.
-adam
alacrity024 is online now   Reply With Quote
Old 03-07-2004, 10:24 PM   #2
SVX WRX
Member#: 26358
2008 EVO X MR
1987 928 S4
is the belt tight? loose ground wire?
why alacrity no SVX Network?
SVX WRX is offline   Reply With Quote
Old 03-08-2004, 11:13 AM   #3
alacrity024
Review Crew
Member#: 49476
svx.net was down, plus i've already asked there.. nobody had a real solid answer for me, so i figured i'd try here, but it looks like i'm getting the same (lack of) answer..
-adam
Old 03-08-2004, 11:34 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Upgrading the wiring between the alternator and the car would certainly be a good idea, it may help and can't hurt.
Do you have a voltmeter in the car? If not it might be worthwhile to install one at least temporarily to see what the system voltage is at various times particularly when the alt light comes on.
Since your problem started with the installation of the underdrive pulley it would most likely be corrected by replacing it with a stock-sized one. I realize however that SVX parts don't grow on trees and aren't cheap.
The light coming on over bumps is another issue, all I can say for now about that is to check all connections at the alt, battery, and vehicle and engine grounds. There may have been a pre-existing problem that wasn't enough to turn the light on until the pulley was changed and the alt output dropped.
Old 03-08-2004, 12:15 PM   #5
alacrity024
Review Crew
Member#: 49476
okay, checked the connections at the alternator and i found something that might be causing the "bump effect"
there's a set of wires that "clips" into the alternator.. they don't bolt down, but they actually snap in... well, the "clip" bit is broken, so it's a little TOO easy to just pull them in/out.. i'll bet a dollar that's what's causing the lights to come on over bumps.
how on earth do i fix that? i can't exactly replace the piece of broken plastic, because, well, it's probably long gone.. i don't really think i could TAPE the thing down to the alternator (besides, it prolly gets mighty hot in there)
could i try to cut the old connector off and splice a new one on? is this a thing i could buy at autozone, or am i going to have to clip one off someone's SVX?
-a
Old 03-08-2004, 12:22 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You might be able to compress the male terminals in the connector for a tighter fit. Try sticking a small screwdriver or whatever in there to make the gap a bit smaller so it grips the female terminal more securely when plugged together. This may help the juice to flow better as well. I'd have to look at the setup to get a better idea, but maybe you can do something with zip ties to hold the connector in place.
Old 03-08-2004, 01:35 PM   #7
alacrity024
Review Crew
Member#: 49476
heehee... "zip ties, the rich man's duct tape!"
-adam
08+ Boost Gauge Alternative (cleanest option in my opinion) Landin2010 Interior & Exterior Modification 31 12-28-2011 06:57 PM
My fog lights in my 04 keep blowing, please help Jay04WRX Electrical & Lighting 7 09-15-2009 12:01 PM
Possible to adjust warning light in Omori 52mm gauges?? DanZ Electrical & Lighting 4 04-07-2006 09:30 AM
Warning Lights in Gauges Hazdaz Interior & Exterior Modification 0 02-25-2002 08:47 PM
