Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 03-07-2004, 06:56 PM   #1
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Default Cross-post Dyno Results from TurboTrix on 3/7/04
AutoSpeedWRX is offline   Reply With Quote
Old 03-07-2004, 06:57 PM   #2
cronic
Member#: 9749
Pm'd you..
cronic is offline   Reply With Quote
Old 03-07-2004, 07:01 PM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Looks good.. that seems almost the same as other cars running 18Gs and PE1820 on that same dyno.
How do you like that Kaaz gearset? Did you break the stock ones?
PaulRex is offline   Reply With Quote
Old 03-07-2004, 07:09 PM   #4
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Yeah i am quite happy with my numbers.
Kaaz gearset is great around town, but on the highway it alsmost Untollerable. doing 70 at like 4250r rpms.
It has worked good in the quarter, but i used to redline in 4th as i went through the traps, now that i am making more power i am goin to have to start worrying about topping out the entire gearbox.
And yes i broke two stock transmissions, the first one the syncros went and it was covered under warranty (luckily) and the second gearbox about 3/4 of the teeth where missing off of 1st gear.
Frank
Old 03-08-2004, 03:01 AM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Are you using the stock 3.90s? or the 4.44s that rallispec sells?
Old 03-08-2004, 10:27 AM   #6
AutoSpeedWRX
Member#: 15334
2002 Wrx Sedan
11.????
Im running the 4.44's from Rallispec which is why my gearing sucks for top end.
Dyno results from IPS Motorsports Dyno Day event pannell77 Mid West Subaru Owners Club Forum -- MWSOC 7 05-26-2009 11:05 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
Injen Posted dyno results for their CAI run on a 2004 WRX trustWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 73 01-24-2004 05:07 AM
Dyno results from MY00 RS!! Keiho Technical Forum Archive 20 06-02-2000 12:55 AM
