Old 03-07-2004, 06:58 PM   #1
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Default 2.5 STI spark plug pics here
For those of you who don't know here are pics of what our stock STI plug NGK IFLR6B looks like against the commonly used NGK BKR7E1X 1 heat range colder plug used on modded WRX's.
The BKR7E1X for comparison is the same size as the stock wrx plug.
A bit of difference eh! Now where can we get colder STI plugs, me thinks at this time we're hooped. I've called the normal web plug vendors etc.
Wombat North is offline   Reply With Quote
Old 03-07-2004, 09:05 PM   #2
2003 sedan
Member#: 24103
Yeah the STi plug extends deeper into the cylinder for sure.
You sure don't want the short threaded plug in that cylinder head(I know you don't).
The heat range difference can usualy be seen by the porcelain length.
I was doing a price check with a vendor the other day and the Iridium plugs were about half the price of the Laser platinum.
Just thought I would share.
Dwight
2003 sedan is offline   Reply With Quote
Old 03-07-2004, 10:40 PM   #3
Monsito
Member#: 40581
04 STi
Did you pull that plug from your STi? It does not look like a happy plug. It looks a little glazed. How many miles do you have on your car?
Monsito is offline   Reply With Quote
Old 03-07-2004, 10:41 PM   #4
Wombat North
Member#: 21267
STI, EWG 8cm Green
Dwight
Thanks
Any vendor you talk with carry colder ones
I posted these pics because just a few posts down is this
http://forums.nasioc.com/forums/show...hreadid=459809
Some are going to be in for a surprise
Old 03-08-2004, 05:00 PM   #5
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
Good Info, thanks for posting that ... I'm just ordering a set from the dealer for now .. hopefully, someone will figure out what a heat range colder plug would be for our STi's .....
Like maybe a Denso or something ....
Kenneth2000 is offline   Reply With Quote
Old 03-08-2004, 07:00 PM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Wonder why it goes into the bore like that?
mr2guru is offline   Reply With Quote
Old 03-08-2004, 07:54 PM   #7
Wombat North
Member#: 21267
STI, EWG 8cm Green
I too would like to know. By the looks of the plug it sticks into the combustion chamber by a few threads?
Old 03-11-2004, 12:02 PM   #8
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
I can't believe that anyone changing their plugs wouldn't notice a difference that BIG!
Thanks for the info I was about to drop the cash on the colder plugs. I would've been pissed!
Keep us informed when there is a colder replacement available.
byron
byroll01 is offline   Reply With Quote
Old 04-20-2007, 02:33 AM   #9
STI30G
Member#: 143359
04 STI
my car keeps misfiring and i cant figure out why? Then i compared my plugs and stock from one step colder is a huge difference? What plugs should i use in my 2004 STI?
STI30G is offline   Reply With Quote
Old 04-20-2007, 02:40 AM   #10
mathetes
Member#: 106238
holy 3-year-old thread batman..
you can use the ngk bkr7e1x a step colder or bkr6e1x for same heat range
mathetes is offline   Reply With Quote
Old 04-20-2007, 11:18 AM   #11
x99percent
Member#: 27108
2004 STi
2004 A4
you can use the ngk bkr7eix a step colder or bkr6eix for same heat range
NO.
Those are plugs for the WRX, and they are too short for the UDSM STi.
As noted in the first post, the stock plugs are NGK ILFR6B (note: 26.5mm reach). One step colder replacements are NGK LFR7AIX (obsolete NGK part, but sparkplugs.com still has some).
Edit: A new part number is NGK ILFR7H ... these should last longer than the LFR7AIX, as they are in the same series as the stock plug (meant to last).
x99percent is offline   Reply With Quote
Old 06-18-2008, 10:09 AM   #12
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
According to NAPA all spark plug numbers are changing and given the scarcity of the new plugs you may want to go with the old ones for now.
NGK one step colder plugs for your STI
LFR7AIX = 2309
ILFR7H = 5245
-J
Jitenshakun is offline   Reply With Quote
Old 10-03-2008, 06:27 PM   #13
eb_rat_7
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
does anyone know if the ILFR7H or LFR7AIX will fit an 2006 wrx 2.5L? also, what is the difference between the two?
eb_rat_7 is offline   Reply With Quote
Old 10-03-2008, 06:43 PM   #14
gtasti
Member#: 152036
2004 Sti
pics dont work btw
gtasti is offline   Reply With Quote
Old 10-03-2008, 08:21 PM   #15
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
Originally Posted by gtasti View Post
pics dont work btw
pics dont work cuz the original post is from over 4 years ago.
vinceGC8 is offline   Reply With Quote
FS/MN: NGK Iridium Spark Plugs (LFR7AIX) 2.5 STi/WRX - One Step Colder WRXEcho Engine/Power/Exhaust 4 09-01-2008 02:42 AM
[B]NGK IRIDIUM Spark Plugs for 2.5 STi - $19 SHIPPED!!![/B] Mr. Quick Engine/Power/Exhaust 1 11-28-2007 04:51 PM
STOCK NGK IR Spark Plugs for 2.5 STi - $19 SHIPPED!!! Mr. Quick Engine/Power/Exhaust 0 11-28-2007 04:50 PM
NEW! 2.5 SOHC spark plug wires (RED) Reason01 Engine/Power/Exhaust 3 09-17-2007 03:14 PM
FS: SC 2.5 Impreza Spark Plug Wires NIB markers Engine/Power/Exhaust 1 08-07-2007 05:24 PM
