Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-07-2004, 10:04 PM   #1
jukes
Member#: 31204
2003 wrx wagon
Winter dirt
Unhappy XT coolant leak, by oil filter?
Changed the oil and filter today, now I have a coolant leak dripping from the small hose next to the filter.
On an 04 XT auto I am assuming this is the oil cooler?
The "clamp" attaching it was just floating around the metal pipe, so I tried to reattach it, but the way it was oriented there was no way to get any type of plier on it. So I removerd it and replaced it with a regular worm type clamp. Now there is coolant running down the hose from somewhere above it. By any chance does someone have a diagram posted that might point me in the right direction to find it?
I tried searching, leak, coolant, cooler, but to no avail.
Why does this always happen on a Sunday night
Thanks
Greg
jukes is offline   Reply With Quote
Old 03-08-2004, 05:04 AM   #2
xt2004
Member#: 52316
2006 STI MY06
I had the same problem when I changed my Oil filter and useing a removale tool. I must in the procces damaged the that small hose. I am sure if you check out this hose it has a hole or cut it. I now have purchased a special subaru tool to remove the filter so this will not happen again.
xt2004 is offline   Reply With Quote
Old 03-08-2004, 10:29 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Here is a close up pic:
I have PN's here:
http://www.scoobymods.com/forums/sho...=&threadid=170
Those pics and info are for the SF Forester's oil cooler so it might not be a bad idea to verify the PN's are the same for the SG.
Peaty is offline   Reply With Quote
Old 03-08-2004, 10:33 AM   #4
jukes
Member#: 31204
2003 wrx wagon
Winter dirt
Peaty,
Thanks, that is just what I needed.
BTW the p/n for the hose/connection is now 807611121.
Now to find one in stock ??
Thanks
Gregg
Old 03-08-2004, 10:38 AM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Check with Subie Gal (Jamie) my guess is she can help. In a pinch my guess is you can use some 3/8" fuel line till you get the right part. You may need to loop it into a pigtail to prevent kinking. Hold the loop together with some wire ties. Just a thought.
Old 03-09-2004, 12:00 AM   #7
jukes
Member#: 31204
2003 wrx wagon
Winter dirt
Thanks all,
Peaty you saved my butt.
Go figure, I got that part number from my local Subi store, Subaru of Morristown.
Managed to bandaid it with a PVC 90 elbow, the hole was right on the 90. Tough spot to work on in the snow on your back..
Jamie, will email you, have a few other things I need.
Thanks
Greg
Old 03-09-2004, 12:35 AM   #8
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Glad you got things mostly sorted out and at least a workable solution
Oil leak on oil filter? alenk37 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-15-2009 02:29 AM
Coolant dripping from oil filter? 03WRX_Rich North West Impreza Club Forum -- NWIC 5 12-15-2008 03:10 PM
coolant leak - from oil filter? Penphoe Normally Aspirated Powertrain 24 06-14-2004 03:40 PM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
