Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 03-08-2004, 02:00 PM   #1
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default C16 vs. Sunoco 104+toluene vs. water injection
I'm hitting the track on Friday, and I want to run my car on race gas instead of water injection (-20 washer fluid injection to be exact).
Am I probably safe to run on my dyno tuned water injection map, even though it'll be race fuel instead of WI? I only had two maps for my car dyno tuned...pump gas, and pump gas+WI.
I'd assume I'll be fine if I use c16...I think I'll also be fine if I use a two gallons of tolune and a gallon or two of Sunoco GT104 on an otherwise empty tank...but I wanted to see what peeps think here on the board, too.
annointed is offline   Reply With Quote
Old 03-08-2004, 05:11 PM   #2
mikaust
Member#: 7468
2008 Outback Limited
Are you tuned for c-16? if so c-16 is the best choice.
mikaust is offline   Reply With Quote
Old 03-08-2004, 05:36 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
C16 would be a waste of money on a water injection/pump gas map. The GT104 should be fine as long as you don't increase boost too much.
Thanks,
Phil (motoxphil)
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 03-08-2004, 05:41 PM   #4
annointed
Member#: 5960
Cool. I'll be running 24 psi, which is my usual WI boost level.
Old 03-08-2004, 08:16 PM   #5
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
C16 is power making potion
mr2guru is offline   Reply With Quote
Old 03-08-2004, 08:22 PM   #6
annointed
Member#: 5960
I have no c16 or race fuel map.
I'm just wondering/trying to confirm if toluene+GT104 provide enough octane cushion for me to run the WI map, which drastically leans out A/F (~12:1, so not too crazy), adds timing, and runs at 24 psi.
I doubt the GT104 alone would suffice, but with two gallons of toluene on top of a little GT104, I think I'll be fine on this map.
Old 03-09-2004, 02:47 AM   #7
Trav4011
Member#: 56881
Toluene is VERY VERY bad stuff... Just use some C16 to be safe.. to your car..... and everyone else around you.
Travis
Trav4011 is offline   Reply With Quote
Old 03-09-2004, 03:40 AM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Travis
Why is toluene so bad? Some people swear by that stuff
PaulRex is offline   Reply With Quote
Old 03-09-2004, 08:30 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
Default C16
Given that C16 fuel contains 10% aromatic content ( translation -- aromatic is mostly toluene) it is not a big deal.
Some unleaded high octane fuels contain up to 45% aromatic hydrocarbons.
Here's the MSDS sheet for Marathon Premium unleaded as an example.
http://www.mapl.com/msds/msds/126mar019.html
Here's the fuel composition limits in Australia.
http://www.aip.com.au/pdf/fuel_%20regs.pdf
Larry
hotrod is offline   Reply With Quote
VP C16 vs Sunoco C16 Special Proven Power Bragging 11 11-14-2007 08:35 AM
Where to get sunoco 104 on black friday giveme5bux Texas Impreza Club Forum -- TXIC 6 11-26-2006 06:05 PM
Nitrous vs. Water Injection ScreaminFast Water/Methanol Injection, Nitrous & Intercooler Cooling 13 07-20-2004 05:02 PM
Water Injection vs moist air ros87 Engine Management & Tuning 2 09-18-2003 09:11 AM
