Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 03-08-2004, 09:20 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default KYB GR-2's vs. stock WRX struts
Is there any advantage with the GR-2's as apposed to stock WRX struts?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-08-2004, 09:48 PM   #2
poison
Member#: 37678
GR-2's don't work on 02+ Imprezas; KYB AGX's work on sedans only, konis work on sedan or wagon
poison is offline   Reply With Quote
Old 03-09-2004, 12:37 AM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
why don't GR-2's work?
Old 03-09-2004, 01:12 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
KYB lists P/N's for the GR-2's for the WRX....IIRC KYB will do special valving on the GR-2's to suite special needs...like really stiff springs.... as well.
The AGX's are usually purchased because they are adjsutable and the cost is only a bit more thatn the GR-2's
poison, maybe you would like to edit your post.
Old 03-09-2004, 04:27 AM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Just wondering because I'm looking at a used setup... GR-2's with eiboch pro's. I'm wondering if there's any advantage to running the GR-2's instead of just running the springs with stock struts.
-- Ed
Old 03-09-2004, 09:35 AM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
GR2 springs are better then stock. Typically for other subarus, the GR2's are 20% stiffer then OEM struts. Whether that carries over to the WRX I'm not sure. Email kyb, and they should be able to tell you.
Legacy777 is offline   Reply With Quote
Old 03-09-2004, 10:32 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
Vaus....you may want to check the P/N's on those used struts to make sure that they are NOT for the GC8...
If they are for the GC8...then buying the WRX specific ones may prove less problematic in the long run.
The WRX GR-2 P/N's are:
rf 334304
rr 334306
lf 334305
lr 334307
Old 03-09-2004, 01:50 PM   #8
poison
Member#: 37678
OK, bad wording in my original post, and I was half wrong: just like with the AGX, they only make a GR-2 for the sedan.
Old 03-09-2004, 03:19 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
KYB lists AGX's(and GR-2's) for the rear of the WRX wagon...they are the same as the sedan....And people have had good success installing the GC8 fronts(AGX's) on the bugeye wagon, as well.
Just so everybody knows
Old 03-09-2004, 09:55 PM   #10
poison
Member#: 37678
So I hear
WTB: KYB gr-2's for a wrx wagon Mikeyrad Private 'Wanted' Classifieds 0 09-13-2009 09:56 PM
DE: 02 WRX Sedan KYB GR-2's tachrev Suspension/Brakes/Handling 5 04-25-2007 08:06 AM
KYB GR-2's with stock springs on GC8? auricom Brakes, Steering & Suspension 22 01-09-2006 10:29 PM
kyb GR-2's on a WRX? Rollo` Brakes, Steering & Suspension 12 07-26-2005 06:43 PM
WTB: KYB GR-2's Nicklbrso Private 'Wanted' Classifieds 1 03-10-2004 08:59 AM
