Old 03-08-2004, 11:52 PM   #1
tony2298
Member#: 27547
Default problem with reverse el gauges
I dont know what happen I started my car up once at night and my whit faced reverse el glow gauges (the ones in the gauge cluster) kept flicking on and off but in a constant pattern . They would turn on to really bright then get a little dim then even dimmer then off then really bright again. for about the ten min. or so ..... so i just kept driving like that then i shut off my car and parked it in my garage the next day i turned my car on and they wouldnt turn on at all.
tony2298 is offline   Reply With Quote
Old 03-09-2004, 01:51 AM   #2
file_id
Member#: 28197
2003 WRX w/ VF34
Check your wiring connections. Either that or sounds like your inverter went bad.
file_id is offline   Reply With Quote
Old 03-09-2004, 02:10 AM   #3
tony2298
Member#: 27547
whats an inverter and if thats what went bad where can i get a new one
Old 03-09-2004, 03:09 AM   #4
file_id
Member#: 28197
2003 WRX w/ VF34
If you have aftermarket reverse gauges then the inverter is the power source.
Old 03-09-2004, 04:12 PM   #5
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
does it have a little thing with buttons to change the brightness and color? Are you sure that wasn't getting squished by something, so it was just cycling through the different brightess settigns? Cause if it was a regular pattern, thats what it sounds like to me!
twizzstyle is offline   Reply With Quote
Old 03-09-2004, 08:16 PM   #6
tony2298
Member#: 27547
yes it has that button but that button only changes the color of the gauges like blue green red and different shades of those colors what was happening was that it was set on one color but it whould just be bright then slowly get dimmer till they where off completly but then back to bright againthen again they would go dimmer and it just kept repeating
problem with reverse devin Transmission (AT/MT) & Driveline 4 08-03-2003 06:06 PM
Problems with reverse datwrx Transmission (AT/MT) & Driveline 32 05-13-2003 05:14 PM
having problem with reverse ramair18954 Transmission (AT/MT) & Driveline 11 12-11-2002 06:37 PM
Problem with reverse gear switching... Apostle Normally Aspirated Powertrain 5 07-19-2001 04:17 PM
