Old 03-09-2004, 01:55 AM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Question Cleaning aluminum completely
Simple green, bug and tar remover, carb cleaner, brake cleaner, none of this stuff works...
Im basically trying to completely clean this old EJ20G I have, and I need a recomendation for a heavy duty Alum cleaner, something that can get rid of all the ancient stains and deposits that get in all the little nooks and crannys. Neverdul and such that I plan on using on the surfaces I plan on shining up nice (like the head plates) but the rest I need something chemical...
Suggestions?
Old 03-09-2004, 03:38 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Try acetone and various scrub brushes/pads....
Beware acetone...it WILL explode
Use it in a well ventelated area no smoking.
If that sin't enough, you may have to have it hot-tanked.
Old 03-09-2004, 06:47 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
600 grit wet/dry sandpaper?
Old 03-09-2004, 07:59 AM   #4
orndog
Member#: 34670
2013 No gears!
Saltine American
Engine degreaser, follow the directions.
orndog is offline   Reply With Quote
Old 03-09-2004, 08:50 AM   #5
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Corn Cobb blasting (alternately walnut shell and or peanut shell, or dry ice)....
(or sand but be careful)
nick
LyveWRX is offline   Reply With Quote
Old 03-09-2004, 11:08 AM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
"Aluminum Jelly", (kinda like "Naval Jelly" )... Nasty powerful acid that will make anything almost like new. Use with caution, read directions...
GLwagon is offline   Reply With Quote
Old 03-09-2004, 11:22 AM   #7
rick-l
Member#: 33868
2003 wrx
srp
Try a search on
dx-533 phosphoric acid aluminum cleaner PPG
someone into aluminum block V8s swears by this but I have never used it.
rick-l is offline   Reply With Quote
Old 03-09-2004, 10:52 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Excellent, know where should I look for the dx-533 or aluminum jelly (I use naval jelly quite a bit, works damn well, but thats the kind of stuff im talking about, something really acidic)
Old 03-10-2004, 12:13 AM   #9
NicGordon
Member#: 24827
2008 Kia Spectra
Will there be a problem with the now clean/stripped alluminum surfaces corroding. Is there some sort of "clear coat" type sealer that you could use to avoid this.
NicGordon is offline   Reply With Quote
Old 03-10-2004, 12:47 AM   #10
suba2u
Member#: 46183
2003 WRX
World Rally Blue
suba2u is offline   Reply With Quote
Old 03-10-2004, 12:52 AM   #11
NicGordon
Member#: 24827
2008 Kia Spectra
Originally posted by suba2u
Quit post whoring. You've posted nothing but smilies in several technical threads within the past couple minutes. This is no way to earn your "specialist" status. If you don't have any quality info to add to the thread, then don't post. Thank you.
Old 03-10-2004, 09:40 AM   #12
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I took care of it Nic- he can start from zero posts again .
Brian
Old 03-10-2004, 12:17 PM   #13
Ging
Member#: 3258
2000 Impreza TS
You could also use a caustic soda solution to etch the surface aluminum away. I use it a lot of times when anodizing aluminum to ensure a fresh surface. However you'd have to be pretty careful about how you apply it since you don't want to get any inside the engine or anything like that.
Something else that may work is oven cleaner. It's super cheap and it'll even strip out hard anodizing! I would try some on a small spot to see how it comes out.
With both of these methods, results vary depending on the alloy you are etching. Sometimes the aluminum will turn dark but still be relatively clean. Also make sure that you flush out every thing really really well when you are done. Oh yeah and work in a well ventilated area.
But then you may not want to use either because they eat away at some of the Al...but they work, especially the oven cleaner :P
Ging is offline   Reply With Quote
Old 03-10-2004, 01:02 PM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Most factory aluminum engines have a clear coat on them when new.
Using a harsh engine cleaner on them can remove this leaving you with aluminum oxide (that white powdery stuff) all over the place.
So, a good cleaner can get it clean but it needs to be resealed when done.
Old 03-16-2004, 02:12 PM   #15
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Take it to a machine shop and have them put it in the hot tank. It rotates and sprays... They will use whatever they need, and you don't have to worry about the EPA or cancer.
20 or 30 bucks?
Plus it will be much cleaner than you'll EVER get it with with a brush and solvent.
Anders, who's done it both ways
anders8 is offline   Reply With Quote
Old 03-17-2004, 10:07 AM   #16
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I have this great stuff for cleaning aluminum pots and pans... it's called Cameo and I get it in just about every supermarket, but again, you'll end up w/ the white aluminum oxide all over everything again in a few months...
mrbell is offline   Reply With Quote
Old 03-17-2004, 11:48 AM   #17
Hawk296
Member#: 14555
1995 Impreza L
Baja
20 or 30 bucks?
I agree. I took a nasty (I mean NASTY) triumph TR4 block to the machine shop to have it cleaned out. They baked it in an oven, threw it in a shot peen kinda thing, then hot tanked it. Absolutley amazing. Never seen anything like it. Came out like new.
After that I took an aluminum ecotec in and had equally impressive results. Its not too expensive and saves you a lot of time and trouble.
Hawk296 is offline   Reply With Quote
FS (OH): complete 2004 STi steering rack, JDM STi aluminum control arms, 04 STi hubs coolblue05 Suspension/Brakes/Handling 17 04-15-2010 03:14 PM
FS WA: STI Aluminum Control arms complete (Polished) wrxwagon253 Suspension/Brakes/Handling 17 10-24-2008 07:16 PM
FS (IL): JDM Version 8 STi front aluminum control arms, low mileage,clean! coolblue05 Suspension/Brakes/Handling 23 03-10-2008 08:10 PM
Aluminum Sub Frame Brace. Completely Removes stock sub frame. WorldOne Brakes, Steering & Suspension 28 09-30-2004 12:53 PM
How do you clean aluminum? (intercooler) 303WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-14-2003 09:43 PM
