Old 03-09-2004, 09:54 AM   #1
mykrrrr
Member#: 733
'13 Focus ST
Question Installing Cruise Control???
I'm sure it can be done but how hard is it and what's needed to do the install???
My STi Ver. 3 GF8 didn't come w/cruise from the factory and I miss my GC6's cruise on long trips.
-mykr.
mykrrrr is offline   Reply With Quote
Old 03-09-2004, 12:50 PM   #2
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I have all the cruise control crap that I'm willing to sell. If you want it just let me know what you need and I'll strip it off of my car. I know you'll need the throttle cable, the electronic module, and the actuator or whatever the large round thing under the hood is called that actually pulls the throttle cable. Then you'll need the switch, but I don't know what else.
garface is offline   Reply With Quote
Old 03-09-2004, 12:58 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah I took mine out when swapping ht eWRX engine in because I never use it...
Old 03-09-2004, 05:41 PM   #4
MNAutomatic
Member#: 50038
2003 WRX Sedan
I am doing a project on my own and got a question you might be able to help me out with since you have taken the cruise control out. Which wire on the button next to drivers seat is the actualy positive wire that gives the button power. I am trying to figure it out so that I can connect something to it but wanna ask before I do
MNAutomatic is offline   Reply With Quote
Old 03-09-2004, 07:15 PM   #5
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
1. Good luck finding room for the RS cruise control servo... if you want to give it a try, you can snag mine for a few days to see if you have room for it.
2. Vacuum operated cruise control servos aren't very fond of positve manifold pressure
3. You should do what I did and install a WRX stepper motor setup. You can check ine out sometime if you like, it's about half the size, and does not need engine vacuum
yamarocket630 is offline   Reply With Quote
Version 9 Jdm Tranny installed Cruise Control no loner works milcic07 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 04-01-2008 07:26 PM
Installing Cruise Control? asterion Transmission (AT/MT) & Driveline 0 06-08-2007 06:57 PM
What would it take to install cruise control? XRS Electrical & Lighting 0 04-27-2007 01:18 PM
Installing Cruise Control Kit - stripped square bolt Keshav Service & Maintenance 8 06-30-2004 10:03 PM
Installing Cruise Control on MT GC8 minx Transmission (AT/MT) & Driveline 0 03-07-2002 04:57 PM
