Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-09-2004, 04:26 PM   #1
ScoobyMods.com
Vendor Sales Rating: (6)
Member#: 23928
1996 STi 555 RHD
Default JDM V8 2.5 Forester Motors
I have 2 JDM V8 Forester Motors, waiting for a new home, available for $3500 + shipping. We need to move these motors to make room for the next shipment of motors and tranny's from Japan.
OK, nitty gritty stuff. This setup comes with:
EJ25 Forester Long Block w/AVCS Heads
Drive By Wire Throttle Body
Tumble Generator Valves
Fuel Rails & STI Yellow Top Injectors
Intake Manifold
Turbo Inlet
Turbo Oil Drain & Feed
Ignition Coils and Spark Plugs
Alternator & AC Compressor
Oil Pump & Pan
Headers
These are low mileage motors (only a few hundred km's) . The setup does not include intercooler, ECU, wiring harness, turbo, uppipe, downpipe, etc.
Shipping should run between $200 & $300 depending on location in the US. Excellent deal here, and supplies are limited.
One of our locals just did a conversion his WRX motor that was blown to one of these JDM V8 Forester motors, and was able to re-use his WRX intake manifold and throttlebody with no major problems since he didn't want to convert to DBW. Once he's finished breaking it in, we can't wait to see the power that his setup makes.
Kevin
Kastle's Korner
www.kastleskorner.com
[email protected]
ScoobyMods.com is offline
Old 03-09-2004, 10:43 PM   #2
Kostamojen
Member Sales Rating: (7)
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
A 2.5L JDM turbo engine?
Kostamojen is offline
Old 03-09-2004, 11:45 PM   #3
Soontobe
Member#: 13432
00 SV650
yes... this isn't the first time forester 2.5's have been sold on this board.
Soontobe is offline
Old 03-09-2004, 11:48 PM   #4
kastle
Frank Army
Member Sales Rating: (6)
Member#: 1457
1999 Outback Sport
Steel Blue Mica
http://www.subaru.co.jp/forester/stiversion/index.html
http://subaru.com.au/explore/foreste...asp?item=23218
These are test units (basically)... Not necessarily bound for Japan...
kastle is offline
Old 03-10-2004, 12:13 AM   #5
WickedRydaX
Member Sales Rating: (21)
Member#: 31900
What is the differece between the shortblock in there, and a STi shortblock? I have a STi shorty right now, but at that price with the heads/cams and all the other goodie I may just get one of them. That would also save me from all the work of pulling apart my WRX motor to swhich the blocks out. How much for shipping to 80503? Also how hard was it to use the WRX TB to rid it of the DBW?
ThankS
MCL
WickedRydaX is offline
Old 03-10-2004, 12:27 AM   #6
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Shipping should be about $150 to you in CO.
The change over was simple as swapping the intake manifold. Since you are still using the WRX ECU, it doesn't need to be aware of the DBW. Technically speaking, you can just swap the throttlebody. I watched Robert from Forced Air Tech take the intake manifold off in 4 minutes. The whole damn thing.
From what I am starting to see, a lot more people are considering the forester swap now that they are realizing they don't have to deal with the DBW. The only problem will continue to be AVCS... I'm not sure anyone has found a work around for it, but I've read enough threads that talked about running it threw the TGV's + some wires.. Doesn't make much sense... :shrug:
The differences in the internals, AFAIK, are the cams (durations) and pistons. I know there have been a ton of threads on the board that have talked about the differences.
-Kevin
Old 03-10-2004, 01:17 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Interesting...
BTW, when will my GC8 shirt arrive?
Old 03-10-2004, 08:12 AM   #8
WickedRydaX
Member#: 31900
ThankS for the info, looks like I am going to stick with the shortblock I have now. Sounds like I may run into some problems with the AVCS if I don't have the right ecu. Do you have any V7 or V8 heads for sale, now or very soon? I am thinking about using a set of them, and I haven't seen any problems with their AVCS when swapped onto the STi shortblock
ThankS again
MCL
Old 03-10-2004, 12:04 PM   #9
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Interesting...
Should be arriving this week.
WickedRydaX -- It's not as much trouble as swapping a shortblock (installation wise) and using the WRX ECU with a ECUTek flash is what people are doing.
I don't have incomplete motors coming over anytime soon, but I'm always looking...
Old 03-10-2004, 09:35 PM   #10
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump
Old 03-10-2004, 11:07 PM   #11
WickedRydaX
Member#: 31900
I will keep thinking about it, but I don't have the money right now, plus I have the shortblock already.
MCL
Old 03-11-2004, 02:01 AM   #12
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Kick azz, I plan on wearing it to the big buttonwillow scoob track day on the 22nd
Old 03-11-2004, 04:03 PM   #13
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump
Old 03-12-2004, 11:33 AM   #14
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
I still have one left... so get it while you can... these are $500 cheaper then another vendor was selling them for... hint hint...
Old 03-15-2004, 10:53 PM   #15
XT6Wagon
Member#: 524
04 STi
I assume these use std subaru turbochargers instead of the twinscroll. Also which oilpan does it use? Spec C or normal WRX?
XT6Wagon is offline
Old 03-15-2004, 11:06 PM   #16
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
They use the standard turbo setup on these engines. IIRC, it uses the WRX oil pan. I can double check in the AM.
Closed Thread
Forester 2.5 Turbo Motor 26k Miles Complete Tatmana Engine/Power/Exhaust 0 11-23-2009 11:06 PM
JDM 2.5 Forester longblock trade chosen_cartel SWIC Private Classifieds 3 03-21-2009 04:38 PM
2.5 sti motor, 2.5 wrx motor olsen726 General Community 19 09-24-2008 02:31 PM
04 2.5 Forester motor in a 99 2.5 RS? R.B. WRX Wagon Subaru Conversions 3 08-24-2007 05:21 PM
JDM V8 2.5 STI Complete Engines Serious Deal! Element Tuning Vendor 'For Sale' Classifieds 33 02-24-2004 10:36 AM
