Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 04-08-2001, 12:07 AM   #1
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post Does anyone know what might cause engine temp misread?
This just started tonight, the temp. gage starts at mid range and then it will go to critical temperature but then fall back down to normal. This is very weird, because i know it can't possibly heat up that fast (it's cold outside). When i pop the hood open it doesn't seem hot either, just normal temp. Anyone know what's going on or had this problem? What sensor is malfunctioning?
popnGEAR is offline   Reply With Quote
Old 04-08-2001, 12:44 AM   #2
Wheels
Member#: 5410
2008 BMW 335XI
Post
maybe the thermostate is not opening properly. Maybe its time to replace it. simply take it out and see how it works in a pan. Fill it with warm water and watch it open. see if it goes all at once or opens slowly.
Maybe try and flush your system out.
Wheels is offline   Reply With Quote
Old 04-08-2001, 12:45 AM   #3
Wheels
Member#: 5410
2008 BMW 335XI
Post
Sorry fill the pan with cold water then heat it up and watch how it opens.
Old 04-08-2001, 12:49 AM   #4
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post
how do i flush the system? i don't konw what that means =\
Old 04-08-2001, 03:16 AM   #5
Wheels
Member#: 5410
2008 BMW 335XI
Post
drain the rad till it stops pouring. Make sure the top is off the expansion bottle and the thermostate is out. The refill with engine coolant.
you can either drop the bottom hose or there is a drain plug on the rad.
Does anyone know what brand oil the engine of a WRX comes stock with ? macrwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-07-2004 06:03 PM
anyone know what the core body temp of a healthy human is? Slvrblt New England Impreza Club Forum -- NESIC 17 03-22-2002 08:48 PM
Does anyone know what offset can the Xt-6 accept. ? DarkLite Brakes, Steering & Suspension 0 02-20-2001 02:14 PM
Does Anyone Know what This is? JP Money Interior & Exterior Modification 25 02-18-2001 07:08 PM
Does anyone know what Primitive Racings new web site is? brat Interior & Exterior Modification 2 12-19-2000 10:56 AM
