Old 03-09-2004, 07:59 PM   #1
legaceee
Member#: 45240
93 subaru legacy
drk green
Default i just ****ed myself royally
anybody want to see pics???ha ha, well, here it is, i was changing my valve cover gaskets today, everything was going well until i started my car, a small oil leak was coming out of the driver side valve cover, so i tightened the bolts, the first two needed it, the last one....BROKE!!! oh my ****ing god, what the **** can i do, the screw part is broken inside of the slot, oil leaks like crazy when i turn on my car, does anybody have any home remedies on how to get out the broken screw or atleast on how to seal it all so that i can still drive, my car is a necessity for school and work, in other words, "IM ****ED!"
legaceee is offline   Reply With Quote
Old 03-09-2004, 08:07 PM   #2
Doughboy
Member#: 27398
2002 Impreza
look into an extracting kit
Doughboy is offline   Reply With Quote
Old 03-11-2004, 01:34 AM   #3
mofoporn
Member#: 4766
2001 2.5 RS
BRP
PM this guy and see what he did to remove the bolt (since he did the same thing you did), also I have all day Friday off if you need help. Hell, between you and my brother, I should open up a subie shop!!!
http://forums.nasioc.com/forums/show...ht=valve+cover
mofoporn is offline   Reply With Quote
Old 03-11-2004, 01:40 AM   #4
mofoporn
Member#: 4766
2001 2.5 RS
BRP
http://www.madelectrical.com/worksho...en-bolts.shtml
exctracting broken bolts
<--- you should dress up like this and dance like this next time we go bowling!!! Or dance like this ---> and dress up like this --->
Old 03-12-2004, 04:39 PM   #5
legaceee
Member#: 45240
93 subaru legacy
drk green
only if you get down on your knees and do this so that i can do this while im watching your bro do this , then we can all do this together !
Old 03-14-2004, 11:42 PM   #6
mofoporn
Member#: 4766
2001 2.5 RS
BRP
But then I'll be like this because you shot it in my eye like this and the people next to us will be like this because we started dancing like this and this
Old 03-15-2004, 01:25 PM   #7
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Getting back on topic how rough did the bolt break? Is there a little ridge on the remnant with which you could grab a hold of it?
I broke one off in my Legacy and DUCT-TAPED the VC to the head. I took it to my job, and a guy used a lock-picking tool to snag a little ridge and work the bolt out.
I recommend replacing the bolts as well when you do this. They've been sitting in the engine for years, doing nothing but expanding and contracting with heat. It's no wonder they're weakened.
DerFahrer is offline   Reply With Quote
Old 03-15-2004, 03:09 PM   #8
legaceee
Member#: 45240
93 subaru legacy
drk green
well the bolt broke off completely inside, but it is all sealed up right now with sealant, there is not leak or nething, im going to be replacing it though, just not until i can get an engine lift
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 01:13 AM
Please help-sheared bolt head off on valve cover bolt silentbob343 General Community 8 08-17-2005 01:23 PM
valve cover bolts torque specs nkodemus82 Service & Maintenance 9 03-03-2004 06:46 PM
Busted Valve Cover Bolt Llamaking Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-15-2004 09:30 PM
valve cover bolts mustardrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-13-2003 03:38 PM
