Old 03-10-2004, 12:26 AM   #1
edubb11
Member#: 23918
2002 WRX (SOLD) :(
Sex? Yes, please.
Default OEM front camber bolts, can they be used in rear?
I was wondering if the camber bolts on the front WRX suspension can be used in the same fashion and location on the rear suspension, without [significant] modification. I was figuring that it is not possible as I found no information on it, but this question has been burning me for a while.
Thanks for any info.
edubb11 is offline   Reply With Quote
Old 03-10-2004, 01:22 AM   #2
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
I have seen this conversion done. You must ream the hole in the upright to the appropriate size and oval the holes in the strut similar to what you find on the front struts.
RokketRide is offline   Reply With Quote
Old 03-10-2004, 01:35 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Better to buy bolts for the rear and not f with it....the bolts can be had for fairly cheap.
Old 03-10-2004, 01:40 AM   #4
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Depends on your intentions.
The "just slap them in" camber bolts for the rear are way smaller in diameter than the stock strut bolts. Not the greatest setup if you really plan to push the car.
Old 03-10-2004, 01:41 AM   #5
edubb11
Member#: 23918
2002 WRX (SOLD) :(
Sex? Yes, please.
I was inquiring because aftermarket bolts look sort of... wimpy, for lack of a better term. The OEM ones look very strong. However, considering they (OEM) would require modification to the bolt holes to fit, I would rather buy aftermarket ones. Now, who makes ones that are good...
Old 03-10-2004, 02:03 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
If you buy good bolts, you shouldn't have any problems...buy junk and ...????
Old 03-10-2004, 02:03 AM   #7
abaxter34
Member#: 34723
fwd FTL!
the h&r's are really beefy, thats what i ordered.
abaxter34 is offline   Reply With Quote
Old 03-10-2004, 02:29 AM   #8
edubb11
Member#: 23918
2002 WRX (SOLD) :(
Sex? Yes, please.
That is what I was asking, who has bolts that look sturdy like the OEM. IMO the Eibach's look like they would break, but that is just based off of pictures I have seen on the internet.
can stock front camber bolts be used in the rear? lukeskywrx Brakes, Steering & Suspension 9 04-05-2008 03:46 AM
SubaruBucks. Can they be used for parts AND labor? plunk10 General Community 8 10-07-2004 10:20 AM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
Anyone try WRX stock front camber bolts in the rear? Cosworth Brakes, Steering & Suspension 2 10-02-2002 06:17 PM
oem front camber bolts fit on rear? RidinLow Brakes, Steering & Suspension 6 10-25-2001 06:23 PM
