Old 03-10-2004, 02:29 PM   #1
loudog800
Member#: 19683
2002 Subaru
WRX
Default transmission flush and fill
I am planning to change fluids in the rear diff and transmission. I am under the impression that I can use just about any 75w90 oil synthetic or not in either one. Can anyone tell me exactly how much oil to add to each after draining? Also do I need new crush washers to perform this maintenence? I have never done this before and just want to be prepared before diving in.
Does anyone know of a post that describes how to do this maintenence?
Can the used tranny fluid be disposed of with regular engine oil?
BS
loudog800 is offline   Reply With Quote
Old 03-10-2004, 02:35 PM   #2
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I'm going off memory here so anyone feel free to correct me (i'm at work so i don't have my big list of values with me...)
Transmission: 3.8 quarts (i think...)
Rear differential: Fill until fluid starts to drip out of differential fill hole
There's no crush washers for either. Just make sure to properly torque down each bolt. I'm sure someone will post the torque values (or you can do a search).
Oh yeah, it helps to have the car on level ground when doing it. Jack up the front/rear to get to the plugs, but when draining the fluid, let the car back down to help drain everything.
-Henry
Old 03-10-2004, 02:54 PM   #3
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Also -- you should pick your fluids carefully... Every body likes a different shifter feel... There are plenty of posts on here about what to choose and what you can expect.... Go to the tranny fourm.
And yes most (if not all) recyclers will accept used tranny fluid also (gear lube not ATF fluid)
Nick
LyveWRX is offline   Reply With Quote
Old 03-10-2004, 03:29 PM   #4
KanosWRX
Member#: 17904
010 STI
There is a washer for the tranny, I found this out the hard way when I saw it in the oil pan after I had already filled the car up with new fluid, had to drain it and then refill it
KanosWRX is offline   Reply With Quote
Old 03-10-2004, 06:44 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
The transmission does take a copper gasket - part no. is 803926070
Transmission takes 3.7 qts. and the rear differential 0.8 qts - both recommend a GL-5 rated 75W90 gear oil
Lots of conflicting info on what to put in and what not to put in the transmission - just look around the site.
I am using Motul Gear 300 in both the transmission and differential and have had no problems at all.
for info on how to do it, check out www.scoobymods.com
Old 03-10-2004, 06:48 PM   #6
thrdeye
Member#: 24569
2011 Impreza WRX
I am using 80w90. Peanut butter for a few minutes, but then it feels really good...I woulda used 75w90, but it is hard to find.
I recommend putting in three quarts and checking the level to see where you are on the dipstick. I over filled and had to drain a bit.
Buy one of those big rubber dish washing gloves so you don't get crap all over your hands.
thrdeye is offline   Reply With Quote
Old 03-11-2004, 06:17 PM   #7
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Suggestions on coolant for 60k flush and fill AnnWD Car Care & Detailing 3 03-16-2010 09:55 AM
Transmission flush ? SUBY2.5 Transmission (AT/MT) & Driveline 13 01-05-2004 09:36 AM
Prestone Flush 'n Fill kit FatCatTurbo Service & Maintenance 13 02-14-2003 11:39 AM
Flushing and filling my auto. NRTmotorsports Transmission (AT/MT) & Driveline 1 11-12-2002 03:18 AM
4EAT Transmission Flush wanna ride in a sti Transmission (AT/MT) & Driveline 3 10-14-2002 12:29 PM
