Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-10-2004, 10:25 PM   #1
garie
Member#: 26607
2002 wrx wagon
Default does the check engine light come on when u need to go in for maintenance?
Hi, my check engine light turned on when i hit 17770 miles while i was driving on the freeway 2 weeks ago. and its stayed on ever since. the car drives fine and it doesnt feel as if anything is different.
I was wondering is it because i havent brought the car in for the 15k service? or is something wrong with my car? i have a turboback with hi-flow cat.
thanks!!
peace,
gary
garie is offline   Reply With Quote
Old 03-10-2004, 10:29 PM   #2
cronic
Member#: 9749
Get it pulled to see whats up.. It does not come on when it needs an oil change or general maintenance>> I would think it is due to the exhaust because you say you were on the freeway when it came on.
D-
cronic is online now   Reply With Quote
Old 03-10-2004, 10:31 PM   #3
edubb11
Member#: 23918
2002 WRX (SOLD) :(
Sex? Yes, please.
go get the code pulled, and find out if you can fix it yourself...
Better yet, just take it to the dealer, it's under warranty still!
EDubb (no more warranty!)
edubb11 is offline   Reply With Quote
Old 03-10-2004, 10:37 PM   #4
cronic
Member#: 9749
Warranty? What is a warrranty?
Old 03-10-2004, 10:53 PM   #5
cnk
Member#: 10757
2013 BRZ Limited 6MT
Subies aren't like Honda's. You probably have the cat inefficiency code, but you'll never know for sure unless you get the code pulled. Drop by Autozone and get it pulled. Then we can tell you how to fix it.
Calvin
cnk is offline   Reply With Quote
Old 03-10-2004, 10:56 PM   #6
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Calvin's right, most likely it's a P0420 code..cat inefficiency code. But this is merely speculation until you pull the codes...Autozone is your friend unless you know someone with a scan-tool.
Mika
finnRex is offline   Reply With Quote
Old 03-10-2004, 11:27 PM   #7
garie
Member#: 26607
2002 wrx wagon
Talking
ok thanks guys for the super fast replies!!
i cant really bring it into the dealer cuz of my mods...im afraid they'll void my warranty....
ill check to see if autozone will pull the cel for me....i just read in another post about cels....a guy said that autozone in california wont pull cels..and that pepboys charges 85 bucks to do it...
ill give autozone a call..hopefully they can do it...
also i plan on sending in my ecu next week to cobb for a stage 2 reflash. will the reflash get rid of the cel if it is a cat deficiency cel?
also one more thing...anyone have any idea why it came on when it did? this is the first time the cel came on...and ive had the turboback on for the past 15k miles...
actually...i doubt anyone can answer that question..since i dunno what cel it is.
ill go get it pulled and see what it is.
thanks again guys!
-gary
Old 03-10-2004, 11:30 PM   #8
cronic
Member#: 9749
THe Cat cel usually comes on when driving on the higway for extended period of time.. If you have to pay 85 for them to pull it just buy a scanner.. Lastly i am not sure about cobb but ecutek can remove codes from the ecu so you wont get that particular cel anymore, i would think cobb could do the same but i am not up to date on the access ecu's.
Old 03-10-2004, 11:46 PM   #9
cnk
Member#: 10757
Regardless of whether or not the Cobb solution removes the CEL, I would still suggest that you find out what the CEL is indicating first. You want to make sure that there aren't any problems and not just cover them. That could lead to future problems.
Calvin
Old 03-11-2004, 08:08 AM   #10
itanium
Member#: 57055
2004 WRX
Hi there
sometimes if the backup battery on the OEM ECU is busted it also causes the CEL to come on. But in your case, it should be due to some exhaust related issue. cheers!
itanium is offline   Reply With Quote
Old 03-11-2004, 08:14 AM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since you're in CA Autozone won't scan your car for free, as you've already heard. If you post in your local forum you should be able to find someone close to you with a scanner who can do it for you, a lot of us have them.
Check Engine Light comes on, whats the problem? sanovichleo Service & Maintenance 7 04-19-2005 06:56 PM
Why did the Check engine light comes on when i install the Blitz Intake? Boosted Wagon STi Forum Archive 17 06-20-2003 10:08 AM
replaced the T and the hose and the restrictor now the check engine light comes on scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2002 11:21 PM
Need help- check engine light coming on, think I am pushing around 20 psi scoobydoo02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-04-2002 10:01 PM
Check engine light coming on and off, seemingly randomly GusS Legacy Forum 8 12-07-2001 02:50 PM
