Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 05-11-2000, 09:57 AM   #1
rschwarzwalder
Member#: 29
2005 Baja
Satin White Pearl
Thumbs up Paintless dent removal works! - PA/NJ
I don't want to fill up this area with a plug for a dent guy, but I want to let everyone know that in the PA/NJ area I found a guy that does good work, brought my baby back to like-new condition. 2 door dings (minor, one in each door) and one ding on the quarter panel (major) removed for $100.00! The doors are perfect, the quarter is only noticeable because I knew it was there!
Thin sheet metal means easier to get dings, but the good side is that the dings are easier to remove! If anybody wants his contact info, email me privately.
rschwarzwalder is offline
Old 05-11-2000, 02:12 PM   #2
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Post
do you know how and what they do to remove dents? well, went to a party this weekend and someone must have leaned on my car or something and now i have one of those little divit indentations on my pass. rear quarter panel. i was/am royally p.o.ed. i just want to know what is involved and if this indentation can be pushed from inside or something? thanx
joostin420 is offline
Old 05-11-2000, 07:00 PM   #3
rschwarzwalder
Member#: 29
2005 Baja
Satin White Pearl
Post
For the doors, he inserts a wedge (commonly used when using a slim-jim to unlock a vehicle)into the door where the window retracts (with the window down), then inserts a long metal rod, bent at one end with a rounded tip. Basically he then uses the rounded tip to "roll out" the ding from the inside of the door. Then for finishing touches (I think to smooth any lines from the rod) he uses a soft plastic pencil-like thing and a plastic headed hammer to tap the outside of the ding. No drilling, no damage.
For the quarterpanel dent, he drilled a small hole in the door jamb under the b-pillar, and used the same type of rod, just longer. Again with the pencil thing and hammer. To plug the hole he used silicon sealer and a rubber plug. The plug when inserted is flush with the body and actually looks like a factory job. No silicone visible, most people won't notice the plug at all.
So you know, I've been around body shops and in the auto salvage business (years ago), and I figured that he was going to use some fancy new tool to remove the dings. It takes some finesse with the rod to work the metal the way he did. I was impressed!
I also watched him do a car on the lot before I let him touch my car. I don't take any risks with my car, especially something that involves drilling or reshaping metal!
HTML code is On
Paintless Dent Removal in NY/NJ ohm Tri-State Area Forum 5 03-21-2010 08:52 PM
How does paintless dent removal work? metros Interior & Exterior Modification 3 03-31-2008 09:24 PM
Paintless Dent Removal in Allentown, PA Henryk Tri-State Area Forum 0 07-15-2007 11:48 PM
Dents on Bodyline...Paintless dent removal? SSFWRX Interior & Exterior Modification 12 12-24-2005 07:43 PM
Paintless Dent Removal (PDR) in Eastern PA? PeeHoLe Tri-State Area Forum 1 11-13-2002 07:40 PM
