Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 03-11-2004, 04:03 PM   #1
dorao
Member#: 29636
2005 STi
Crystal Grey
Question Anxiously waiting for the 05 STi... Parted my WRX
Hello,
I'm getting an 05 STi when they arrive (hopefully in the next few months) and
I've reverted my 02 wrx to stock. Below is a list of what I have... What is
worth keeping for the STi? Most are obvious, but just wanted to run it by you
guys.
Once I've finalized the list, I hope to sell off the remainder locally .
Thanks in advance,
Masuo
*Keep*
Exedy hyper single
ss clutch line
Apex'i N1 Coilovers
cusco front strut brace
cusco rear strut brace
cusco front sway bar
perin endlinks
TXS turbo back exhaust
TXS test pipe
Defi gauge pod
Defi link system w/ 3 bf gauges (egt, oil pres., fuel pres.)
Blitz DTT
STi engine mounts
STi tranny mount
Cusco Oil Catch Can
*Sell*
ss brake lines
axxis ultimate pads
rota attacks w/ Azenis - SOLD
cusco rear sway bar - SOLD
TXS uppipe
TXS UTEC w/ remote switch
TXS TMIC (v2)
VF34
STi injectors
Walbro fuel pump
STi Hood scoop (midnight black pearl)
APS splitter
PIAA 1000 Driving Lights (w/ extra bulbs & mounts for WRX)
Momo Race Air Leather shift knob - SOLD
dorao is offline   Reply With Quote
Old 03-11-2004, 05:08 PM   #2
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
How much for the rear sway bar?
I would be very interested.
Thanks,
Mike
dman918 is offline   Reply With Quote
Old 03-11-2004, 05:09 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Can't use the injectors or fuel pump.
Old 03-11-2004, 05:10 PM   #4
blue-sun
Member#: 15934
I have a set of almost brand new OEM rear brake pads if you want them for your return to stock. . .
david
blue-sun is online now   Reply With Quote
Old 03-11-2004, 05:12 PM   #5
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
Masuo, you and I are gonna have to have a long conversation and a significant exchange of funds/car parts.
mrbigisbudgood is offline   Reply With Quote
Old 03-11-2004, 05:14 PM   #6
Joker 13
Member#: 38669
2008 FSXT
I'm fairly certain that the fuel pump is the same. I'll double check tonight. We just installed one in an STI and I believe it had the same PN.
Joker 13 is offline   Reply With Quote
Old 03-11-2004, 05:23 PM   #7
SUBE555
Member#: 24043
2005 Legacy GT Sedan
The tranny mount I don't think will work with the 6MT.
I think the VF34 is actually a little smaller, but if you want better low-end response, a VF34 would be able to give you probably another 50 or so nicely reliable ponies, but more bottom end than stock if my turbo sizing is correct (and it's ball-bearing.) If you were to keep that, I'd keep the IC too. Could always get the Accessport when they release it in the next few months for the STi. The splitter would also likely be useful with the TXS IC.
You'd probably be able to easily run stock injectors and pump.
So do the STBs make that much of a difference on the GD's? I was under the impression they didn't.
Also, aren't the 5MT and 6MT clutches different? So why keeping the 5MT Exedy clutch?
So what parts will all be going into an STi, from what you have and what you plan on purchasing?
SUBE555 is offline   Reply With Quote
Old 03-11-2004, 05:35 PM   #8
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The tranny mount is exactly the same.
The issue with the TXS TMIC is it sits too far back, the TB on the STI is moved backwards due to the throttle by wire, so I don't think it would fit with the AC lines there. There is barely any room for it in the WRX.
The VF34 is actually slightly larger than the VF39 that comes on the STI. It has a larger exhaust housing than the VF39.
STBs make a little difference but there are more gains to be had with swaybars and other suspension stuff. Rear STB makes a decent difference in a wagon.
You can use a 5MT clutch in a 6MT, the 6MT clutch disk/pressure plate is only minimally larger, like 2-3mm.
Old 03-11-2004, 07:16 PM   #9
SUBE555
Member#: 24043
Nice to remedy my inaccuracies. Gotta learn something new every day.
Only reason I thought the 6MT had a different mount is because I've seen them advertised differently.
The throttle by wire theoretically shouldn't add much if anything, but that's just theoretically.
Got the specs on the VF39 and VF34? I know IHI numbers and sizes rarely coorelate to any guideline. I'm just wondering because I've never really saw any numbers on the VF39. Does the VF34 have better spool characteristics or anything to really set it apart?
Old 03-11-2004, 08:19 PM   #10
dorao
Member#: 29636
2005 STi
Crystal Grey
dman918: Sorry, but somebody already called dibs on it, but I have yet to see cash in hand . I'll let you know if the guy defaults.
dwx: thanks for the info as usual .
blue-sun: I got my stock ones too. Thanks anway.
mrbigisbudgood: sure thing! I'll look forward to doing business with you.
JoKeR 13: Thanks! I might not need it though... I'd like to know the difference between the walbro and the stock Sti one.
SUBE555: Actually... I've decided to sell the VF34, and go with a 20G or GT32. I'm probably going to go with a FMIC this time so I'll sell the TMIC w/ goodies as well (even if it fits). Still need to decide on engine management....
Thanks for the input guys!
Anything else?
Masuo
Old 03-11-2004, 08:45 PM   #11
F22-Raptor
Member#: 18311
2009 C63 AMG
HOw much for the I/C?
F22-Raptor is offline   Reply With Quote
Old 03-12-2004, 08:22 AM   #12
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Out of curiosity, how much would you be looking to get for the utec w/switch?
tcs007 is offline   Reply With Quote
Old 03-12-2004, 11:03 AM   #13
spanner
Member#: 18791
2002 WRX wagon
Silver!
How much for the uppipe?
I'm definitely interested in the UP!
-Mark
spanner is offline   Reply With Quote
Old 03-12-2004, 12:24 PM   #14
TheYellowDart
Member#: 42856
2006 Cooper S conv
Talking
Damn you had a nice ride there. But i understand the need for the sti
Emailed you on some parts.
Dan
TheYellowDart is offline   Reply With Quote
Old 03-15-2004, 01:01 PM   #15
dorao
Member#: 29636
2005 STi
Crystal Grey
I'll be putting together a FS thread in a few days.
Thanks for the help guys!
Masuo
Old 03-15-2004, 01:36 PM   #16
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
Masuo,
Can I hold on to that TMIC for you ... I'll keep it nice and warm and comfy until you find it a new home..
MustGoFast is offline   Reply With Quote
Old 03-15-2004, 01:56 PM   #17
dorao
Member#: 29636
2005 STi
Crystal Grey
Originally posted by MustGoFast
Masuo,
You got the STi hood scoop right?
If I were you, I'd want my TMIC and APS splitter...
Masuo
Old 03-15-2004, 03:19 PM   #18
MustGoFast
Member#: 33370
2002 Impreza WRX
I don't wanna buy them but I'd happily hold onto them for you .. I wanna do a FMIC but I'm trying to save for a house instead.
Old 03-15-2004, 03:52 PM   #19
bartx
Member#: 51852
04 2.5RS
YATCH
how much if its still up for grabs, for the hood scoop?
thanks bart.
bartx is offline   Reply With Quote
Old 03-18-2004, 05:50 AM   #20
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
wanted the APS splitter. How much
runner19 is offline   Reply With Quote
Old 03-21-2004, 06:10 PM   #21
dorao
Member#: 29636
2005 STi
Crystal Grey
pm me your email address
Masuo
how much for an 05 STi part out? Surgical22 General Community 20 06-25-2008 09:19 PM
Which aftermarket exhaust for the 05 STI has the least fitment issues? Moshpit552 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2005 09:34 AM
need to change the brake for the 05 sti with 18k miles any good suggestion? fishdotcom Brakes, Steering & Suspension 7 08-09-2005 09:55 PM
Has any stage packages for the 05 STi been released yet? subaru18 General Community 1 08-04-2004 01:56 PM
who's waiting for the MY05 STi instead of 04? lionken07 News & Rumors 5 01-08-2003 02:29 PM
