Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-12-2004, 10:00 AM   #1
Turbometrics
Vendor
Vendor Sales Rating: (0)
Member#: 55087
Default LM-1 Air/Fuel Meters!
The LM-1 is air/fuel ratio meter that offers extreme accuracy at an unprecedented value! Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
• The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program:
• The standard LM-1 includes a Bosch wide-band oxygen sensor and cable, cigarette-lighter adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. The LM-1 ships with a Bosch sensor, however, it can also function with other wide-band sensors, including Honda/NTK and VW sensors.
For a limited time only! $314.10 + shipping!!!
Order yours now!
http://www.turbometrics.com/store/pr...oducts_id=2651
Turbometrics is offline
Old 03-12-2004, 03:04 PM   #2
SleeperWRX
Member#: 8179
thanks for getting mine out to me so quickly I can't wait to get it installed...great price and service!
SleeperWRX is offline
Old 03-12-2004, 06:23 PM   #3
03WRXMA
Member Sales Rating: (7)
Member#: 35081
2012 WRX
How much extra is the add on for RPM data logging?
03WRXMA is offline
Old 03-12-2004, 08:32 PM   #4
rexorama
Member Sales Rating: (1)
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Yes, more information on add ons please. EGT sensors and RPM switch etc etc
rexorama is offline
Old 03-13-2004, 02:25 AM   #5
Arnie
Member Sales Rating: (5)
Member#: 1725
99 Subaru Impreza
GF silver
Just want to say that I played around with one of these last night. Very impressive little piece of technology. Its a very cool device to have if you do your own tuning. Its great to be able to monitor and record one's A/F ratios for detailed analysis. Great price.
Question: can you install the sensor in the 3rd Cat O2 bung? Will this provide an adequate place to get readings from? Or does one have to tap into the downpipe?
Arnie is offline
Old 03-13-2004, 10:50 AM   #6
scobSTI
Member#: 40695
2011 wrx
satin white pearl
Default ??
scobSTI is offline
Old 03-13-2004, 12:15 PM   #7
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Basically you can although closer to the turbo will give you more accurate readings. I wouldn't tune "on the edge" from that point, I'd tap a bung closer.
rexorama is offline
Old 03-13-2004, 12:31 PM   #8
Turbometrics
Vendor
Member#: 55087
Rexorama is right....tap a bung in your downpipe.
All the LM1 Accessories are available here:
http://www.turbometrics.com/store/ad...0becde3e4c5a41
Thanks!
__________________
Old 03-13-2004, 03:18 PM   #9
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Innovate Motorsports - Exhaust Clamp_
Is this a tail pipe mounted sensor?
Basically I'm trying to find out what my options would be for a fast easy sensor hookup to get a decent idea what is going on in with my engine as well as hooking the system up to friends cars on the fly. Would the above pictured device be the proper tool for this? I was just thinking that access to the 3rd cat is a bit easier than the downpipe for "quick" installation.
thanks!
Arnie is offline
Old 03-13-2004, 06:16 PM   #10
Turbometrics
Vendor
Member#: 55087
Yes, that is a tailpipe "sniffer"
__________________
Old 03-16-2004, 01:09 AM   #11
WickedRydaX
Member Sales Rating: (21)
Member#: 31900
To use the "sniffer" you need to be cat-less, otherwise you will be tuning post cat, which is not the same as pre cat. If are running a cat, the sensor must be before it.
MCL
WickedRydaX is offline
Closed Thread
FS (SoCal): Innovate LC-1 Air Fuel Meter 06stiman Engine/Power/Exhaust 2 02-20-2007 10:38 AM
Innovate Motorsports LM-1 Air/Fuel Ratio Monitor (Wideband O2) Dasani Engine/Power/Exhaust 11 11-05-2006 07:51 PM
Innovate Motorsports LM-1 Air/Fuel Ratio Monitor (Wideband O2) Dasani TXIC Private Classifieds 2 11-05-2006 07:50 PM
LM-1 Air Fuel Meter -- WideBand 02 Andursun0013 Private 'For Sale' Classifieds 13 03-01-2005 05:38 PM
Innovate Motorsports LM-1 Wideband Air/Fuel Meter, K&N filter Scott4DMny Private 'For Sale' Classifieds 4 02-25-2005 12:06 AM
