Old 03-12-2004, 10:28 AM   #1
Richard Sierra
Member#: 29528
02 WRX wagon V7 RA
-C conversion
Default Wideband o2 sensor placement, tuning experts please help!
I was on the dyno yesterday and was getting some funky o2 numbers from the dyna pak wide band. I have two bungs, one is approx 6-8 inches from the turbo in the downpipe, the other is close to the rear o2 sensor location. I have an external wastegate that is downstream of the "first" o2 bung
We had the dyna pak wideband in the downpipe close to the turbo and my LM-1 Innovate wide band in the further downsteam bung.
The dyna pack reading showed very lean conditions under full load (above 12.5:1) yet the LM-1 showed pretty stable readings around 11.5:1. We swapped the dyna pak wideband to a new one and it still showed the same lean conditions.
The car never detonated on 93 even with the alleged lean condition. We were running 21-22 psi boost.
Is the wideband too close to the turbo and overheating causing funky numbers or does the downstream wastegate possibly affect AF readings?
The other intersesting thing is at a stable load and boost the AF's stayed constant.
I have an V7 Ra motor with a GT30-11, a Perrin big MAF, Walbro pump, stock fuel rails and PE 800's.
Richard Sierra is offline   Reply With Quote
Recommended Placement of dedicated wideband o2 sensor... 05Scooby Newbies & FAQs 8 06-03-2009 02:14 PM
Wideband O2 sensor placement? Superorb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 02-12-2007 09:08 AM
WTB: Knock Link with sensor, and a wideband o2 sensor with monitor SolidSnake Private 'Wanted' Classifieds 2 05-04-2006 09:30 AM
wideband O2 sensor AFTER a cat acceptable for tuning? rex n effect Engine Management & Tuning 11 12-12-2005 04:52 PM
Building a portable tuning station - wideband O2 sensor 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-29-2003 09:36 PM
