Old 03-12-2004, 05:37 PM   #1
03WRXMA
Member#: 35081
2012 WRX
Exclamation Can someone take a look at this open loop fuel map...
Its for a Stage 2 car tuned to use open loop fueling, my question pertains to the boost. Is this map in OLB?
Code:
[START][MAPGROUP1][MAPGROUP]
Map Name:-[STG1 NEW]
Map Comments:-[16.5 psi peak]
Fuel Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]
      [0]   [-0.4]   [-0.4]   [-0.1]    [0.2]    [0.3]    [0.3]    [0.3]    [0.3]    [0.3]    [0.3]
      [0]   [-0.2]   [-0.2]    [0.1]    [0.4]    [0.9]    [0.9]    [0.9]    [0.9]    [0.9]    [0.9]
      [0]    [0.1]    [0.1]    [0.6]    [0.9]    [1.6]    [1.9]    [2.1]    [2.3]    [2.4]    [2.4]
      [0]    [0.6]    [0.6]    [1.1]    [1.4]    [2.1]    [2.4]    [2.6]    [2.8]    [2.9]    [2.9]
      [0]    [0.6]    [0.6]    [1.1]    [1.4]    [1.7]      [2]    [2.2]    [2.2]    [2.3]    [2.3]
      [0]    [0.6]    [0.6]    [0.9]    [1.2]    [1.5]    [1.8]      [2]      [2]    [2.1]    [2.1]
      [0]    [0.4]    [0.4]    [0.7]      [1]    [1.1]    [1.6]    [1.8]    [1.8]    [1.9]    [1.9]
      [0]   [-0.1]   [-0.1]    [0.2]    [0.5]    [1.2]    [1.2]    [1.2]    [1.2]    [1.3]    [1.4]
      [0]   [-1.9]   [-1.9]   [-1.2]   [-0.2]   [-0.2]   [-0.5]   [-0.4]   [-0.3]   [-0.2]   [-0.1]
      [0]   [-1.9]   [-1.9]   [-1.2]   [-0.2]   [-0.2]   [-0.5]   [-0.7]   [-0.6]   [-0.5]   [-0.4]
      [0]   [-1.5]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.4]   [-0.6]   [-0.5]   [-0.4]   [-0.3]
    [0.2]   [-1.8]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.4]   [-0.6]   [-0.6]   [-0.5]   [-0.4]
    [0.5]   [-1.8]   [-1.8]   [-1.1]   [-0.1]   [-0.1]   [-0.1]   [-0.3]   [-0.3]   [-0.3]   [-0.3]
    [0.4]   [-1.5]   [-1.5]   [-0.8]    [0.2]   [-0.1]   [-0.1]   [-0.3]   [-0.2]   [-0.1]      [0]
    [0.5]   [-1.4]   [-1.4]   [-0.7]    [0.3]      [0]      [0]   [-0.2]   [-0.1]      [0]    [0.1]
      [0]   [-1.4]   [-1.4]   [-0.7]    [0.3]      [0]      [0]   [-0.2]   [-0.1]      [0]    [0.1]
      [0]   [-1.1]   [-1.1]   [-0.4]    [0.6]    [0.6]    [0.9]    [0.9]    [0.9]    [0.9]    [0.9]
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]
   [-100]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]
   [-100]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]
   [-100]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]
   [-100]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]
   [-100]     [20]     [17]     [17]     [17]     [16]     [16]     [15]     [14]     [14]     [14]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [15]     [14]     [14]     [14]
   [-100]     [20]     [19]     [19]     [19]     [18]     [18]     [17]     [16]     [16]     [16]
   [-100]     [21]     [20]     [20]     [20]     [19]     [17]     [17]     [17]     [17]     [17]
   [-100]     [21]     [21]     [21]     [21]     [20]     [17]     [17]     [17]     [17]     [17]
   [-100]     [22]     [22]     [22]     [22]     [21]     [19]     [19]     [19]     [19]     [19]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [21]     [21]     [20]     [20]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [21]     [21]     [21]     [21]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [22]     [22]     [22]     [22]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [23]     [23]     [22]     [22]
Boost Map
      [0]      [0]      [0]    [400]    [400]    [400]    [400]    [400]    [400]    [400]    [400]
[END][MAPGROUP][0380D][EOF]FINISHED
This is in Open Loop Boost, Correct?
03WRXMA is offline   Reply With Quote
Old 03-12-2004, 05:43 PM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default Re: Can someone take a look at this open loop fuel map...
Closed loop boost control. Open loop values are 0-100
MAD REX is offline   Reply With Quote
Old 03-12-2004, 05:43 PM   #3
03WRXMA
Member#: 35081
2012 WRX
Default Re: Re: Can someone take a look at this open loop fuel map...
Ugh, yeah I meant CLB..
Why the hell are the values all the same though
Old 03-12-2004, 06:33 PM   #4
nmyeti
Member#: 4980
That's from a road tune i did this week. I wanted the car to make 16psi from 30%-100% tps under just about any condition the turbocharger could support it.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 03-12-2004, 06:42 PM   #5
03WRXMA
Member#: 35081
2012 WRX
-Nathan
www.turboxs.com
Jermaine sent it my way
So it is CLB, correct?
Its smooooth and quick on my car FWIW.
-Dave
Old 03-12-2004, 11:58 PM   #6
nmyeti
Member#: 4980
Yes it's a closed loop boost map.
Old 03-13-2004, 10:55 AM   #7
03WRXMA
Member#: 35081
2012 WRX
Thanks Nathan,
Its pretty cool running the 16 psi at almost any throttle position, almost makes it feel very NA like.
Old 03-13-2004, 03:33 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Can someone take a look at my logs? cr125r Engine Management & Tuning 51 01-22-2007 06:36 PM
can you guys take a look at this motor for me? NJsilvernotch Impreza Forum 22 07-22-2006 03:42 PM
SE Michigan: Could someone take a look at my ride? sizzflair Mid West Subaru Owners Club Forum -- MWSOC 2 02-02-2006 11:08 PM
Looking for a subwoofer? Please take a look at this. mvorchard Car Audio, Video & Security 1 06-15-2005 04:37 PM
Can somone take a look at this? (Strut mount & spacer question + pics) AcquaCow Brakes, Steering & Suspension 8 02-18-2005 03:58 AM
Message Board Statistics All times are GMT -4. The time now is 05:54 AM.
