Old 03-13-2004, 06:06 PM   #1
Skylab
Member#: 4263
Question Burnt out Fog Light button
How do I replace the orange indicator bulb for the fog light button? Button still functions...the light doesn't.
Thanks.
Skylab is offline   Reply With Quote
Old 03-13-2004, 09:10 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
take the switch out IIRC you can get to the bulbs from the back of the switch.
you might have to pull it apart.
Might be easier to just change the switch.
Jay
Old 03-13-2004, 10:04 PM   #3
Skylab
Member#: 4263
Do I have to pull the lower dash portion out to remove the button?
Old 03-14-2004, 09:10 PM   #4
COwannago
Member#: 6972
Yes. I thought I had the same problem, but it turns out the switch is broken, the fogs won't turn on, don't know how I managed to do that, but I get the correct indictations that the correct pins are getting power. I hate driving at night without the foglights.
Nick C.
COwannago is offline   Reply With Quote
Old 03-15-2004, 02:32 AM   #5
Scooby Blue
Member#: 12112
MY00 RS
Thanks.
Did this last week.
Take off the lower dash panel, it makes it easier. 3 or 4 screws, 2-3 on the bottom and 1 on the side. From there you can get to the switch, disconect the harness and push forward. Switch pops out. There are actually 2 bulbs in the switch and you can remove them from the side using a flat head screwdriver. The upper one is the orange one. The bulb is tiny and I had to go to the dealer to get it. ($2-3)
Something to note too...the bulb is actually clear with a orange rubber cover. I needed to take off my original cover and put it on the new bulb, I reused the "rubber"... Anyways, I ended up tearing the cover but got it on the new one and it looks fine. So to save you some trouble check and see if the dealer has bulbs with the cover already on.
added image
Scooby Blue is offline   Reply With Quote
Old 03-15-2004, 02:35 PM   #6
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
the replacement switch is $27 from a dealer. i'm not sure how much the bulbs are..
i was able to get at mine by removing the fuse door.
for the actual switch, to pop it open you have to pry both sides over the tabs at the same time, and pull it down..
mine had clear bulbs, and green film on the lens... i scraped off the green, and used some red bulb condoms...
DISCOPOPE is offline   Reply With Quote
Old 03-16-2004, 06:47 PM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Peaty is offline   Reply With Quote
Burnt out dash lights steven765 Baja Forum 6 09-21-2009 10:25 PM
Burnt out fog light deaton Vancouver Impreza Club Forum -- VIC 6 01-04-2007 10:09 PM
Burnt out fog creature546 Electrical & Lighting 1 06-01-2003 01:33 PM
Fog light button not illuminating Imhotep Service & Maintenance 12 01-16-2003 03:16 AM
('93-'01) Fog light button... broken Rich L Impreza Forum 22 12-30-2002 10:09 PM
Message Board Statistics All times are GMT -4. The time now is 01:32 PM.
