Old 05-29-2000, 08:58 AM   #1
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Question Searching Forums question
Two things. I see why you removed the delete a thread function, the database still holds the record of it and when it posts up under a search, oops its not there. What I wanted to know was:
(1) how come when you search for old stuff it comes back broken linked? This is because you moved your db and it is still referenced to the old location? Is there any way to rectify this (an update command)?
(2) Uh damn I forgot what 2 was. Gotta do something about that memory. Had something to do with the searching.. ooooh right. How come you cannot search all forums anymore? You all removed it. I used it all the time when I was not sure where a post was located by remembered the content.
NickSTi is offline
Old 05-29-2000, 10:51 AM   #2
Grind
Member#: 596
Post
Hi Nick. Because you are such a great guy, I thought I would answer it for you.
It is because the moderators and secretly conspiring with SOA to disavow all knowledge about the RS, so that when the WRX comes down they can get away with badging it as an RS. Hope that helps.
Grind is offline
HTML code is On
07 sti airbag light just came on in cluster. I have searched forum threads already A7Xraider Service & Maintenance 4 01-19-2010 11:55 PM
1.8L plug gap, searched forum, no answer max427 Service & Maintenance 2 01-14-2008 04:49 PM
Search forums using Google. Magnum626 Newbies & FAQs 7 10-25-2007 08:02 PM
Cannot Search Forums...Help! links_courses Off-Topic 6 08-23-2003 10:59 AM
search function question? WRX IS HOT Newbies & FAQs 6 07-05-2003 10:34 AM
