Old 12-10-2000, 10:05 PM   #1
Sam Kaufman
Member#: 3135
98 2.5 rs
red
Question Fuel Pressure Regulater
Just woundering if anyone has put a adjustable fuel presure regulator on a n/a car. What kind of gains did you get and was it worth it. Basiclly, would it be a waste of money? Thanks
Sam Kaufman is offline
Old 12-10-2000, 10:07 PM   #2
Sam Kaufman
Member#: 3135
98 2.5 rs
red
Post
Sorry, I should have put it in Mech. section. I will not let this happen again.
Old 12-10-2000, 10:08 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It's not necessary with any year N/A RS. Depending on the model year, the car will run rich or lean in certain parts of the powerband at full throttle. Increasing fuel pressure across the board can possibly solve the problem of running lean, but at the expensive of running extremely rich everyplace else, which fouls plugs, cats, & the environment.
Something like the Apexi S-AFC is what prety much all of us use to correct the fuel mixture.
RidinLow is offline
HTML code is On
fuel presure regulater intallation.. emsti2004 Water/Methanol Injection, Nitrous & Intercooler Cooling 4 07-16-2008 10:48 AM
fuel pressure regulater scoooby03 Factory 2.0L Turbo Powertrain 1 10-07-2006 08:52 AM
fuel preasure regulater dohced Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-10-2005 06:43 PM
Fuel Pressure or Oil Pressure? krave Factory 2.0L Turbo Powertrain 2 03-01-2002 11:59 AM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
Message Board Statistics All times are GMT -4. The time now is 01:26 PM.
