Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Vancouver Impreza Club
Old 03-15-2004, 04:46 AM   #1
Lantec
Member#: 48685
2010 Prius
Default Gas Gauge
Is it just me or does it not to go past the "F" mark whenever I fill up???? it just stays at like..... a tad under full.... do I have to over fill for it to show that?
I've had the needle show past "F" like 3 times since I've had the car........
anyone else notice this?
Lantec is offline   Reply With Quote
Old 03-15-2004, 12:40 PM   #2
Kevin
Member#: 1082
2015 Q50S
Dull
Default Re: Gas Gauge
Nope, you must be going insane.
Actually, the gauge on my car will go past the 'F' whenever I fill up. Mines an '02 though.
Kevin is offline   Reply With Quote
Old 03-15-2004, 02:28 PM   #3
deft
Member#: 46624
2004 WRX
World Rally Blue
Mine goes past the full every time. And i stop after the one click at chevron.
deft is offline   Reply With Quote
Old 03-15-2004, 03:05 PM   #4
quest
Member#: 42402
- Finder of Porn
-Bringer of tears...
mine splooges a bit of gas out if I fill it all the way up, so I'm always a bit under F.
quest is offline   Reply With Quote
Old 03-15-2004, 04:23 PM   #5
Tricky
Tu ne cede malis sed contra audentior ito
Member#: 28960
2002 Stock WRX Wagon
MBP with door dings
...and it takes awhile to get under the first quarter and then Whoosh! all the gas goes out of the tank in a few days!
Tricky is offline   Reply With Quote
Old 03-15-2004, 05:33 PM   #6
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
I thought I was the only one with this "splooge" problem. It's weird, for me the splooge causes excess fuel to dribble out onto the ground, but it seems to happen internally (ie. behind the bodywork) somewhere.
Anyways, I get above F, but only if I fill it up all the way. So, to get "above F", AND avoid "splooging", I now do the following:
1. Fill at "full-trigger-squeeze" until you are within the last 5-10 Litres or so of gas.
2. Back off on the gas pump squeeze trigger, and continue to fill the last 5-10 Litres at "half-trigger-squeeze" until the gas pump automatically shuts off at the FIRST CLICK. Don't do the 2nd or 3rd click top-off, as I've heard it's unnecessary for most modern cars and is just a waste - it may even be bad for your car depending on who you talk to.
(BTW Don't back off too much or the pump's automatic shut off may not work and you will make a mess as you overfill WAY TOO MUCH)
3. Shake out the pump to get the last few drops out of the pump $$ (and, to avoid dribble onto the bodywork as you pull the pump away from the car -- I hate that!)
tada!
just my 2cents on filling up
BTW - the sube is the first car I've had to do this for
-- Dendrobium
Dendrobium is offline   Reply With Quote
Old 03-15-2004, 06:09 PM   #7
Lantec
Member#: 48685
2010 Prius
Hmm... so maybe the problem is, the pump is going way too fast and not filling up as much...
unless I'm insane......................
Old 03-15-2004, 06:50 PM   #8
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Nope, you're not alone. My MY00 has been doing that since day-1. If I fill up to the first-click of full, my gas gauge is just below the F-line. If I top it off 3-5 times, it barely gets to the middle. I've never had my gas gauge go past the F like most other cars.
I still get nearly 500km/tank in mixed city/highway driving though.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 03-15-2004, 07:04 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
WRX's can actually get a CEL from over filling or from putting the gas cap back on incorrectly.
tora is offline   Reply With Quote
Old 03-15-2004, 07:28 PM   #10
[YeS.SiR]
Member#: 56602
2012 SWP STi
Don't gauge by eye, gauge by (1) How many litres you're actually filling up divided by (2) how many kilometres you get per fill. You can compare with others to see if you're drastically out of proportion.
[YeS.SiR] is offline   Reply With Quote
Is the Low-gas warning light wired with gas gauge? Hazdaz Electrical & Lighting 5 06-17-2003 11:28 PM
Problem gas gauge or not to worry? moogooob Normally Aspirated Powertrain 1 03-27-2002 07:12 PM
gas gauge misreading alphabenson Service & Maintenance 1 01-28-2002 09:19 PM
My gas gauge reads 50% off. anyone else? Eric SS General Community 15 12-20-2001 09:42 AM
('93-'01) gas gauge malfunctions? wop Impreza Forum 4 08-30-2001 10:35 AM
