Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-15-2004, 12:11 PM   #1
dtesta
Member#: 52587
2004 Bajo Turbo
Default Oil Change
My Baja is due for it's first oil change. Messy job that I hate to do but I hate the whole drop it off or wait in line for a 15 minute job routine even worse so I try to do my own changes. Has anyone done this before? How much hassle is it? How about synthetic oil? Is it worth it?
Thanks!
dtesta is offline   Reply With Quote
Old 03-15-2004, 01:30 PM   #2
hatake
Member#: 34811
04 Baja T
Dyno/synth issue is probably personal preference for the most part. I'll stick to dyno and change it frequently.
Aside from that, if you have never done it before, I suggest you take off the undercarriage, in order not to spill a large quantity of oil (I surely made a mess, and I've been changing oil myself for 5 years). That little hatch ain't cut it. Also, be careful not to damage the water hose that goes into the engine, next to oil filter. Some FXT owners have damaged the hose and caused leakage. I still had to lift up my car, even with 8.4 inches of ground clearance.
It's a PITA, but makes the relationship more intimate
hatake is offline   Reply With Quote
Old 03-15-2004, 06:36 PM   #3
cadillacjake
Member#: 49969
2004 Baja Turbo
Black Granite Pearl
I've always done my own oil changes, and on any of my newer cars I've always used Mobil 1 10W30 synthetic. Granted, on an 8 quart engine it costs about $40 to do it myself, so imagine what that would cost if I paid someone. To do it on yours, it should be under $30 with synthetic. Once you figure out the best way to drain the oil (skid plate dodging, oil splash avoidance) and how to fenangle the filter on and off without torching your hands, it's not bad and only takes 10 min or so. It's a learning process, but also gives you a reason to look over your car underneath and underhood. Just good practice I think.
cadillacjake is offline   Reply With Quote
Old 03-22-2004, 12:22 PM   #4
-jv-
Member#: 57845
2003 Baja
Oil changes on the Baja are really quite simple. The owner's manual shows you how to remove the undercarriage port to access the filter and oil pan. The filter is very easy to access from underneath as is the oil pan itself, although both are a bit far back from the front of the car.
Two pieces of advice:
1. Spend $6 and get a plastic used oil pan with an internal reservoir. The one I bought holds 15 quarts (almost 3 oil changes) and has plugs to ensure no spillage. Your local auto parts store can dispose of the oil for you. It is MUCH neater.
2. Try lying a length of 2x4 underneath each of your front tires. The couple of inches extra on height should be plenty enough to get underneath and perform the change.
-jv- is offline   Reply With Quote
Old 03-22-2004, 09:21 PM   #5
dtesta
Member#: 52587
2004 Bajo Turbo
Default Thank's for the input..
Looks like a good weekend project.
Just did my first oil change/gear oil change since i got my car ayobreezie Newbies & FAQs 12 07-19-2006 08:29 AM
change oil filter with every oil change? BlackBeastie Service & Maintenance 1 03-15-2003 07:29 PM
2nd oil change and which oils to change? makofoto Service & Maintenance 4 12-28-2002 08:07 PM
