Old 03-15-2004, 02:32 PM   #1
ATERYU
Member#: 55047
2002 wrx
blue
Default JDM or EDM
ok i am going to buy either the JDM or EDM headlights today but before i do anyone that has the JDM ones have you noticed if the beam pattern is drastic enough to go and buy the EDM's? i am alos planning on getting an HID set to go along with them so please share some info. Thanks.
ATERYU is offline   Reply With Quote
Old 03-15-2004, 02:43 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The patterns of the two are exact opposites-
JDM/RHD pattern-
\__ \__
EDM/LHD pattern-
__/ __/
You can aim the JDMs lower and more to the right, but they will always be projecting light in the wrong direction for use on LHD roads. Also aiming them down low enough to protect oncoming traffic will make less light available for you.
The beam pattern can be modified by opening the lights and grinding the internal plate, but it isn't an easy job.
EDMs are the way to go, especially if you plan to install HIDs which would only make the problem worse. The EDMs also have the leveling motors which the standard JDMs don't, although to make those operative you'll need the switch and harness (unless you make your own).
Old 03-15-2004, 03:10 PM   #3
sevendhappy
Member#: 16283
Teh Car n00b!
G-Club represent!!!
http://forums.nasioc.com/forums/show...hreadid=511012
Of course, we are pretty close to the garage, so the cut offs don't look that different. If we were farther away, you'd notice a bigger difference between the two cut offs as the jdms shoot off higher to the left, while my edms shoot off higher to the right.
sevendhappy is offline   Reply With Quote
Old 03-15-2004, 03:16 PM   #4
JIN
Member#: 27731
I would get the EDM. At least in the future, you can toy with the idea of making a pnp levelling switch for your lights. Whereas in the JDM non HID projector lights, there is no levelling motor in there at all. The fact that you have the correct beam pattern is cool too.
Jin
JIN is offline   Reply With Quote
Old 08-03-2006, 05:45 PM   #5
vivalajustin
Member#: 120142
2005 impreza wrx sti
world rally blue
ok so i drive on the right side of the road
wtf should i buy
and what are all these abbreviakgstions LED HID JDM EDM
vivalajustin is offline   Reply With Quote
Old 08-03-2006, 05:51 PM   #6
vivalajustin
Member#: 120142
world rally blue
what what is
__/ and
\__
Old 08-04-2006, 12:10 AM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Holy old thread.
In the US and other countries that drive on the right side of the road, we use lights with an LHD beam pattern. LHD stands for Left Hand Drive as in the side of the car where the driver is. RHD is the opposite and is for cars in countries that drive on the left side of the road.
__/ and \__ are approximations of the beam patterns for LHD and RHD E-code lights respectively. E-code lights have a pattern with a sharp vertical cutoff directly ahead and a rising portion that illuminates the curb side of the road. As you can see, using E-code lights with the incorrect beam pattern for where you live/drive will cause the rising part of the beam to be directed into oncoming traffic.
Old 08-04-2006, 12:43 AM   #8
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
jdm on left, edm on right
taerron is offline   Reply With Quote
Old 08-08-2006, 10:06 PM   #9
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
finally a comparison pic.. i dont see that much of a difference..i have brand new JDM's and after many ppl saying DO NOT put hid's in them...some say ill be alright..i might do it for the hell of it, im not opening my brand new lights(unless someone local will do it) and im not selling because i wont get my 900 bones back
BuggeyEYED is offline   Reply With Quote
Old 08-08-2006, 10:40 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I wouldn't go by that pic alone. The beam pattern does project upward to the left, and it will present a problem to oncoming traffic.
Old 08-08-2006, 10:43 PM   #11
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
that pic shows the general idea of what they will look like. but trust me, back up and try that pic again and it will look much worse.
Old 08-09-2006, 02:24 AM   #12
Grey Ghost
Member#: 43070
Sorry to high jack, but is there anyway one can get the EDM projectors for less than $700? Is it possible to order the EDM's from local subaru dealer?
Grey Ghost is offline   Reply With Quote
Old 08-09-2006, 03:06 PM   #13
DLUX WRX
Member#: 35153
2003 WRX
nope, you cant get them at the dealer.
DLUX WRX is offline   Reply With Quote
Old 08-10-2006, 03:14 AM   #14
sano.
Member#: 117125
jdm....
sano. is offline   Reply With Quote
Old 08-12-2006, 09:45 AM   #15
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
i agree, but if the car was a little further away, it would be very obvious. plus, you can already see the glare on both of them. the edm isn't as bad as the jdm one, but if you want to do it right, the projectors are not the best ones to use.
WTB: JDM sti grill for 03 WRX, JDM hood scoop, or JDM OR EDM headlights teg_09 Private 'Wanted' Classifieds 0 05-30-2009 03:22 PM
WTB jdm or edm projector headlights hid or non gsteclipse33 Private 'Wanted' Classifieds 0 02-28-2005 01:36 PM
JDM or EDM passenger (right) side headlight GoRacerXGo Private 'Wanted' Classifieds 2 10-11-2003 02:55 AM
OR: wanted - JDM or EDM STI headlights kimragone Private 'Wanted' Classifieds 4 10-07-2003 11:43 PM
JDM or EDM light condensation TonyWRX Interior & Exterior Modification 4 10-17-2002 11:11 AM
