Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
Old 03-15-2004, 01:43 PM   #1
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
Default radiator fan turns on with key just before crank posistion...
was it always like this? i havent really noticed until recently...when my battery went completely dead in about 5 mins with the key in just before crank. i watch my voltage meter on my turbo timer and it drops pretty quickly...so i can't keep my headlights on for more than 5 mins unless the motor is turning.
ps. i do have jdm headlights with aftermarket hid's...
any help?
BoostedAWD is offline   Reply With Quote
Old 03-15-2004, 01:48 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No, the fans shouldn't run in the run position, unless the engine is already hot enough for them to come on.
The only circumstance I know of where this would happen is if the green diagnostic connectors under the dash (the ones that are normally unplugged) are connected together, this activates a diagnostic mode where, among other things, the fans will be running. You'd also get a constant flashing CEL if this were the case, and you didn't say anything about that.
Old 03-15-2004, 11:49 PM   #3
BoostedAWD
Member#: 19519
2002 Subaru WRX
World Rally Blue
nope no cel's.
i checked today...and actually my radiator fan isn't on, in run position. i think the car was hot or something...but i realized that my hid's suck my voltage down bad, because as soon as i turn them on, it drops my voltage .1v's every second and i think i need atleast 9 volts to crank right?
Old 03-16-2004, 12:21 AM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Things to Check..
If you have the A/C Button Pressed in the Fans will Run in the On Position.
SubaruImpreza_power is offline   Reply With Quote
Old 03-16-2004, 07:22 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Every time you turn your HIDs on they draw a high amount of current for the first few seconds, then they settle down to normal operating mode and actually draw much less than halogens. If you're sitting there turning them on and off it may very well drain the battery. Each ballast can draw 10-15 amps at startup.
Impreza Turns off, then turns on with no key Jutboy Electrical & Lighting 2 02-23-2009 12:40 PM
flexalite radiator fans for wrx with koyo radiator Nick W Factory 2.0L Turbo Powertrain 0 12-17-2005 08:20 PM
CEL flashing and fans turning on on 05 STI vapore0n Factory 2.5L Turbo Powertrain 13 05-22-2004 12:15 AM
Why does my radiator fan turn on? T-WRX Factory 2.0L Turbo Powertrain 6 04-27-2004 06:17 PM
Have a problem with the car... radiator fan always on.. Impreza94L Southern California Impreza Club Forum -- SCIC 2 01-15-2003 06:14 PM
