Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 03-15-2004, 04:54 PM   #1
irmiger
Member#: 54241
2004 Forester XT
Java Black
Cool iPod solution!
*** This mod works with the stock Forester XT 6-disk head unit...no modifications are required !!! ***
I just finished my iPod adapter and plugged it in...wow what a difference over the FM adapter! I made it myself in around half an hour, then it took about fifteen minutes to install. I just followed the directions of BOXXER on this thread: http://forums.nasioc.com/forums/show...hreadid=459029
The list of items needed are as follows:
1. 13pin mimi din plug ($9.94) http://www.connectworld.net/cgi-bin/iec/DN13M
2. 3ft of patch cord with 1/8" male stereo headphone jack on one end (a patch cord can be bought from Radio Shack and one end cut off; $4.99) http://www.radioshack.com/product.as...5Fid=42%2D2387
3. OPTIONAL - Belkin Auto Kit for iPod w/ Dock Connector ($49.99...can get cheaper if you shop around online, ie Amazon is $31.99) http://catalog.belkin.com/IWCatProdu...duct_Id=149006
4. A CD with a continuous blank track. I downloaded John Cage's song 4'33" 16 times on a CD (for those of you who don't know John Cage is famous for recording four minutes of perfect silence and calling it a song!) or you can use Sony's free Sound Forge Demo download and record one continuous blank track for the whole length of the CD.
My total cost was around $50 for the whole thing but you can do it cheaper if you don't get the Belkin. It just makes it a cleaner installation and charges it to boot.
To make the adapter:
1. Cut one end off the patch cord and make the length around 3ft.
2. The phono patch cord has either 4 wires in it (2 center wires and 2 wrapped around the outside) or 3 wires (2 center and 1 wrap). Solder each of the 4 wires to the 13pin plug terminals 1,2,3,4 for R+,R-,L+,L- respectively.
(If you have 3 wires, the two center ones are L+ and R+, the outer wrap is a common ground and must be split in two and soldered to L- and R-)
3. Reassemble the plug and you're done...that's it!
To install the darned thing:
1. Carefully pull up on the rear edge of the plastic shifter boot housing. It will release from the center console revealing 2 screws on the bottom edge of the center panel.
2. Unscrew those 2 screws and set aside.
3. Now the hard part, you have to use a flat screwdriver and pry the center panel out. The Suabru instructions call for putting thick tape around the edge of the center panel on the dash itself to prevent maring. Pull gently on the lower edge of the center panel while carefully prying around the edge with the screwdriver. I found prying the screwdriver handle inwards worked best for me.
4. Unclip the 3 connectors behind the panel
5. Unscrew the 4 screws holding in the radio.
6. Pull out the radio and plug in your adapter.
7. Feed the adapter cord wherever you want it to go. I recomend through the center tunel to the storage container between the seats.
8. Reinstall everything in reverse order.
9. Plug in the optional Belkin adapter. Plug in the patch cord to the Belkin adapter.
10. Put your blank track CD in the changer.
DONE!!!
All I do now is play my blank CD, select the iPod songs I want, and the music comes out beautifully. Enjoy.
irmiger is offline   Reply With Quote
Old 03-15-2004, 09:17 PM   #2
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
Wink You Stink! Just kidding.
I just bought an iTrip. This is a must do mod for me.
Richard
SuperRuWRX is offline   Reply With Quote
Old 03-15-2004, 11:06 PM   #3
irmiger
Member#: 54241
2004 Forester XT
Java Black
Just took some pictures to show how it all turned out!
1. This shows the length of the patch cord I have left. It's extra long in case I want to use my Sonic Rio instead of the iPod.
2. With patch cable tucked in, also shows hole I drilled. Very clean.
3. The whole thing together
4. Lid closes right over cord without any problems. Belkin cord is also long enough to hit the dash if I want to get a iPod dash mount. To top it off, everything just drops into the center console when I leave the car so no one can steal it!
Old 03-15-2004, 11:36 PM   #4
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Just an FYI. iPods are not water proof.
Old 03-16-2004, 07:38 PM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
If you can will you repost the mod in the contributions section of Scoobymods? I think it would be a good addition
Peaty
Peaty is offline   Reply With Quote
Old 03-17-2004, 12:38 AM   #6
frankramo777
Member#: 15724
08 FXT sports
wrb
ipod geeks
frankramo777 is offline   Reply With Quote
Old 03-17-2004, 06:00 PM   #7
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
hooray for John Cage .. his estate sued a british composer for releasing another silence track saying it infringed on the Cage silence composition .. and Cage won a six figure settlement ..
this mod would work on the WRX with 6 disc changer?
ronaldwrx is offline   Reply With Quote
Old 03-18-2004, 01:19 AM   #8
irmiger
Member#: 54241
2004 Forester XT
Java Black
I thought it might me a little ironic that I downloaded it! I hope Cage's estate doesn't come after me.
Couldn't say (since I have a FXT), but if the WRX shares the same 13pin round cd changer plug in back...then yeah, it should!
Old 03-23-2004, 08:35 PM   #9
Blackskull
Member#: 5616
2002 Impreza WRX
WRX is a panasonic. Totally different connector.
I found some other info that might be of interest.
cbus pinout
http://www.mp3car.com/vbulletin/show...089#post106089
and another supposed cbus pinout.
http://www.kipshively.com/kip/stereo/cbus.htm
Those 2 pinout diagrams do point to the possibility that the clarion protocol is I2C. Here's the spec.
Now, any EE gurus out there can come up with a way to fool the deck into thinking there's a changer connected without using a PIC or what have you? Maybe all the deck needs is a pusle signal or even high or low signal to the data line and clock line?
Blackskull is offline   Reply With Quote
Old 03-23-2004, 09:26 PM   #10
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
sucks for us wrx ipod owners .. i guess im still waiting for the alpine ipod headunits .. patience ..
Old 03-24-2004, 12:40 PM   #11
SASniper
Member#: 57913
irmiger,
can you repost pics, or update links ... I wanna see the awsome job you did
SASniper is offline   Reply With Quote
Old 03-24-2004, 01:58 PM   #12
Ken S
Member#: 1895
05 Leg GT Ltd. W
Great job. I've been worried about how in the world I'm going to connect my iPod without a cassette adaptor when I upgrade to either a FXT or Legacy GT. Neither model has cassette players anymore!
Ken
Ken S is offline   Reply With Quote
Old 03-24-2004, 03:34 PM   #13
SASniper
Member#: 57913
I think this might be the same trouble I had with my Sony amp ... requires a digital START and STOP signal to initiate the flick to AUX mode I'm no EE ... so I don't think it's going to be easy.
Old 03-30-2004, 01:18 PM   #14
SASniper
Member#: 57913
Well I got my connector last night. Wired it up ... hooked it up ... burned a blank 70min CD ... and I'm STOKED!!!!
Works a charm!
Couple of tips:
If you slightly mash the grey plastic surrounding the console with your screwdriver ... find a piece of plastic (nylon or teflon's best) and rub it quite hard over the scrape. It comes out as good as new Usually your screwdriver handle works well!
If you want a full length quiet CD, download a program called Sound Forge (demo), open a new file, then Edit->Insert Blank (70min blank ) ... save file, burn, and VOLLIA!
Old 04-03-2004, 01:23 PM   #15
FormerSubaruTech
Member#: 58775
2000 Forester L
I did an install similar to this.
http://www.mindspring.com/~pmbenn/iPod
I hacked a belkin adapter to make it work. these can be had for around $10 on ebay (open box).
FormerSubaruTech is offline   Reply With Quote
Old 04-04-2004, 01:08 AM   #16
irmiger
Member#: 54241
2004 Forester XT
Java Black
I just updated the finished pictures above...had to switch my image host. Yahoo wouldn't let me hotlink the pictures to this site, so I switched providers. Enjoy!
Old 04-23-2004, 12:20 PM   #17
SASniper
Member#: 57913
I've been noticing some high frequency engine rev noise coming through using my Belkin iPod adapter. I heat shrunk all my connections, so I know it's not that.
Found some info on this incase anyone else has this problem:
http://www.ipodlounge.com/forums/sho...t=engine+noise
Old 04-23-2004, 12:59 PM   #18
SASniper
Member#: 57913
This is also good info for a ground loop:
http://www.audiocontrol.com/techpapers/tech1002.pdf
Old 05-16-2004, 02:20 AM   #19
ttl
Member#: 61041
2000 L
Red
I just found some good info about cd changer wiring:
CD Changer Protocols:
http://www.mictronics.de/?page=cdc_proto
Panasonic CD Changer Emulator - PIC 16F84A controlled:
http://www.lafrog.com/cdcemu/
Maybe someone can make a real AUX input for Panasonic 6-CD changer? (16-pin connector).
ttl is offline   Reply With Quote
Old 05-19-2004, 05:07 AM   #20
irmiger
Member#: 54241
2004 Forester XT
Java Black
I've actually had a few questions regarding hiss. It seems that using the Belkin Auto Adapter does cause a slight hiss. Also reported is audible engine noise. Both of these issues are usually the result of a poor ground. The following info is posted on Crutchfield's Tech Pages and should fix things:
Noise Problem Troubleshooting: Noise from portable device
If you have noise just when you are using a Portable (CD/MD/MP3) Deck, then the problem is most likely ground-related. Most portable players are connected to the head unit using either a cassette adapter, or through 'AUX IN' jack(s) on the front or rear of the head unit. The power for the portable is then obtained through a twelve-volt adapter that is plugged into the cigarette lighter.
The problem lies in the fact that using the cigarette lighter, which is using a different ground than the head unit, creates a ground loop between the two units. Test by unplugging the power converter from the portable, and then playing the portable through your head unit using the batteries of the portable for power. If this eliminates the noise, then you could change the ground location for either the cigarette lighter, or the receiver, so that they are both grounded to the exact same location.
Good Luck !!!
Old 06-07-2004, 06:47 PM   #21
tsteub
Member#: 62961
2004 Forester XT
Thumbs up
Thanks for this mod!!
It worked great, per your instructions. I've been
living with monster fm transmitter for a few
months now, I forgot how much better direct
connection sounds!
thanks again,
...Ted
tsteub is offline   Reply With Quote
Old 06-26-2004, 07:50 PM   #22
irmiger
Member#: 54241
2004 Forester XT
Java Black
If you want a full length quiet CD, download a program called Source Forge (demo), open a new file, then Edit->Insert Blank (70min blank ) ... save file, burn, and VOLLIA!
The program is called Sound Forge 7.0 trial version and is available from Sony at http://mediasoftware.sonypictures.com/.
Just open a new project, set the Mode to "Punch-In (record a specific length)", then adjust the "Length" to the full time of your blank cd (70,75,80 min). Hit record and wait. After the 75min are up, drop in your blank cd and burn it!
Old 06-28-2004, 07:09 PM   #23
SASniper
Member#: 57913
^ Sorry my bad
Old 07-07-2004, 08:48 PM   #24
irmiger
Member#: 54241
2004 Forester XT
Java Black
Originally posted by SASniper
^ Sorry my bad
Hey, no prob! I like your idea better. I actually replaced my multi track cd with a continuous one like yours and it works much better. I hit repeat on the radio and when it's done it just starts over at the beginning. Thanks for the info - James.
Old 07-08-2004, 03:34 AM   #25
byis
Member#: 37653
2003 OBS
Outback Sport 03 - Will this mod work?
Anyone have an idea if the base model cd-player (no cassette) for the Outback Sport 2003 includes the same adapter? If all else fails I can always take it out and check but wanted to check here first...Fingers crossed that its the same!
byis is offline   Reply With Quote
The iPod Solution For Those Who Have Time colinrobinson Car Audio, Video & Security 18 06-20-2014 01:36 PM
The best Ipod Solution for '06 Tribeca owners WITH rear DVD... HB_Dad Tribeca Forum 0 06-05-2006 04:29 PM
IPOD solutions? bwagner Car Audio, Video & Security 26 11-24-2005 01:49 AM
aesthetically pleasing ipod solution captain_dingaling Car Audio, Video & Security 7 11-11-2005 11:55 PM
