Mid Atlantic Impreza Club
Old 02-15-2008, 11:49 AM   #101
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Originally Posted by AcquaCow View Post
I'm not sure he would...
If I can run H6's with 4-pots up front, which already transfer brake bias to the rear due to less front brake torque...
Running the H6 rears with RS front calipers shouldn't really upset it that much at all.
Ideally ctimpreza should get wrx rotors for the front as well.
-- Dave
You can run them...the question is "should you?"
I know I noticed a big brake bias change when I added the H6.
Jard is offline   Reply With Quote
Old 02-15-2008, 12:15 PM   #102
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Find subysouth's spreadsheet and calculate it out?
Old 02-15-2008, 12:45 PM   #103
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
This one: http://www.main.experiencetherave.co.../brakemath.xls ?
-- Dave
AcquaCow is offline   Reply With Quote
Old 02-15-2008, 12:51 PM   #104
Butt Dyno
Member#: 17301
is the "dark side"
That's the only one I know of...
Old 02-15-2008, 12:58 PM   #105
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
According to that then,
He'd be keeping the stock 276x24mm front rotors and upgrading the rears from 266mm to 290mm...
According to the spreadsheet, that's only a 10% shift to the rear if he uses stock pads front and rear and is on stock pads now.
I'll re-run those #'s, as that sheet doesn't have specific info for the GC... I had to find a matching legacy entry...but I haven't had time to look at piston diameters in the calipers...
Using the same substitution, the sheet quotes 13% increased rear bias for 4-pot/H6 over stock RS setup, but only 2% if you do WRX front brakes with H6 rear.
-- Dave
Old 02-15-2008, 02:39 PM   #106
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
-- Dave
What's the comparative # for an '02 WRX adding the H6 rear?
Just so I can compare...
Old 02-15-2008, 03:59 PM   #107
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
10.38% rearward.
Assuming you are using the same pad compound before/after.
12.64% rearward if you were on stock pads prior to the conversion and street pads after.
-- Dave
Old 02-15-2008, 04:06 PM   #108
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
10.38% rearward.
-- Dave
I went to Bobcats at the same time I did it. That's cool info...thanks for crunching the numbers.
Now I know what a 12.64% rearward bias shift feels like.
Old 02-15-2008, 04:14 PM   #109
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I'm gonna double-check that spreadsheet this weekend...
I want to figure out which legacy entries = GC, as I figure piston size will play into this...but not my too much...
-- Dave
Old 02-15-2008, 09:30 PM   #110
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Alright, it looks like all of the caliper piston diameters are the same size for the Legacy/WRX/RS for the years I'm concerned with, so the #'s I posted earlier are right.
The spreadsheet has a calculator tab where you just pick before/after scenarios and it tells you the % difference...there's no manual calculation involved thankfully.
-- Dave
Old 02-16-2008, 02:39 AM   #111
ctimpreza
Member#: 162724
1996 Impreza
Green
I have a brighton with the rear drums . This probally throws the calculations way off of front rear bias %. H-6 brakes seem like a cost effective way to increase braking power, while also coverting to disc. Lots of great information.
ctimpreza is offline   Reply With Quote
Old 03-18-2008, 11:21 AM   #112
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I recently nabbed a good deal on a set of 06 WRX 2-pot rears and decided to plug them into the brakemath.xls sheet.
The "H6" and rear 2-pots have identical brake torque according to the sheet, so my bias will not change... =)
I will remain at my previous 22% rearward shift.
[Edit]This is possibly not true, please see my post below[/Edit]
Here's some more info from that spreadsheet regarding upgrades from WRX brakes to various 4/2-pot combos...
Assuming stock WRX brakes as a starting point...
Subaru 4-pots added to the front, stock rear: 7.9% rearward, 9.6% rearward if upgraded to street pads all around.
Brembo's added to front, stock rear: 10% forward, 12.3% forward if upgraded to street pads all around.
Subaru 4-pots front, subaru 2-pot rear: 18.2% rearward, 22% rearward if upgraded to street pads all around.
Subaru 4-pots front, brembo 2-pot rear: 11.83% rearward, 14% rearward if upgraded to street pads all around.
Brembo 4-pot front, subaru 2-pot rear: .2% rearward, .33% if upgraded to street pads all around.
Brembo 4-pot front, brembo 4-pot rear: 6.9% forward, 7.5% forward if upgraded to street pads all around.
Just some #s to think about.
-- Dave
Old 04-17-2008, 12:32 PM   #113
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Wow, so upon doing some more research I have discovered that brake torque % F/R is not the same as brake bias F/R.
We can pretty much disregard anything referencing that in this thread
More info here:
http://forums.nasioc.com/forums/show....php?t=1416144
-- Dave
Old 04-17-2008, 01:08 PM   #114
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I just wanted to quote this post, as I think it is the most important in the brake torque vs bias question.
Originally Posted by Legacy777 View Post
Mike,
I've looked at my sheet, and inputted some data in TCE's calculater. However there are some differences in the inputted data....
For kicks, I put in data on TCE's calculator for the STi brembros to try and match my sheet. I used .39 for pad Cf, both front & rear. The main difference I can see is that there may be some difference in how the effective disc diameter is calculated, but it shouldn't change things too much. I do not know the calculation TCE is using to calculate the effective disc diameter, and how it compares to the effective disc diameter given in the factory manuals.
What I did was subtract the effective disc diameter from the outer disc diameter. That is what I used for the pad height. For the brembro front's I got 2.28" & rear I got 1.89". When I put all that info in I got a Percentage of front bias of .742
I did the slider WRX config using 1.85" for the front pad height & 1.41" for the rear pad height.....I came up with a Percentage of front bias of .744
For the 4 & 2 pots I used 1.53" for the front pad height & 1.42" for the rear pad height. I came up with a Percentage of front bias of .694
So....pretty close to your numbers. I used all the data from my spreadsheet....I think you had a slightly different piston diameter then I did for one caliper....I don't remember which now.
Anyway....the bottom line and where I think your seeing the difference coming from is due to the fact I am using a percentage of brake torque change, while the numbers you're getting off of TCE's calculator are actual calculations of bias. It's been a while since I made all the changes to the spreadsheet, but I do recall talking with TCE about this very issue, bias vs. brake torque. A 25% change in brake torque may seem like a lot, but it may only yield a 0.05 percent change in bias when looking solely at the numbers. Actually vehicle response will vary depending on a lot of other variables, including weight shift, suspension, etc.
So that's my stab at what you're seeing, and why you're seeing the differences between the two calculators. I'm open to any and all comments as it's been a while since I've looked at this stuff.
Josh
-- Dave
Old 06-17-2008, 12:54 PM   #115
sick1.8t
Member#: 22345
2003 RSX
black
can a similar upgrade be done to the front with the front brackets and front h6 rotors?
sick1.8t is offline   Reply With Quote
Old 06-17-2008, 01:00 PM   #116
VipersEatLotus
Member#: 21007
aren't fronts H6 the same size stock WRX?
VipersEatLotus is offline   Reply With Quote
Old 06-18-2008, 04:04 AM   #117
sick1.8t
Member#: 22345
2003 RSX
black
could be. maybe i'm thinking of the legacy gt calipers that are an inch bigger. i think those are thicker than the wrx rotors though.
Old 06-18-2008, 04:08 AM   #118
sick1.8t
Member#: 22345
2003 RSX
black
rotors i mean, rotors are an inch bigger.
Old 08-04-2008, 02:49 PM   #119
BoostUnderPressure03
Member#: 117724
2003 WRX
So after reading everything I'm pretty well confused. Is the rear braking bias something to be concerned with or not? I will be doing the H6 upgrade with Hawk HPS pads, new fluid and SS Lines.
BoostUnderPressure03 is offline   Reply With Quote
Old 08-04-2008, 09:10 PM   #120
Gonz
Member#: 18642
2005 Impreza WRX STi
Do you have the Subaru 4pots up front or stock 2003 brakes?
if you have the stock 2003 brakes up front, there is nothing to be concerned about with the H6 rears. I had that setup for a few years; drove on the street, autoX & track with no issues.
G
Gonz is offline   Reply With Quote
Old 09-17-2008, 10:36 PM   #121
WejR20X
Member#: 58101
G
So what if one was going from full stock to subaru 4-pot fronts and was wanting to do H6 rears? would it be recommended or discouraged based on regular driving with occasional track time?
WejR20X is offline   Reply With Quote
Old 01-15-2009, 12:54 PM   #122
j-speedracer
Member#: 48897
02 WRX
i'm about to do the H6 upgrade on an '02 wrx and i'm seeing on subarugenuineparts that there are 2 options
bracket + clip for $125
or
bracket only for $115
what clip are they talking about and is it necessary or something you can reuse off the stock wrx brakes?
a friend who has done the upgrade said he didnt use a clip but i want to double check before purchasing.
j-speedracer is offline   Reply With Quote
Old 01-15-2009, 02:31 PM   #123
LGTONCOKE
Member#: 170908
2005 SWP LGT WAGON
Team Grocery Getter.
nice write up good for people who want better brakes
LGTONCOKE is offline   Reply With Quote
Old 01-15-2009, 03:13 PM   #124
orfsubarupartsdude
Member#: 104453
2010 FXT
I usually sell the brackets only.
orfsubarupartsdude is offline   Reply With Quote
Old 01-15-2009, 03:23 PM   #125
kumanchu
Member#: 146696
you should be able to reuse the clips that are currently on your brackets.
kumanchu is offline   Reply With Quote
h-6 brake upgrade in s.fl ease27 South East Region Forum 4 12-13-2005 07:51 PM
Brake upgrade for '98 Leagacy Outback bagio Legacy Forum 3 03-19-2002 08:17 AM
Brake upgrade for '98 Leagacy Outback bagio Brakes, Steering & Suspension 0 03-11-2002 01:51 AM
brake upgrade for 95 L? DoinkMobb Brakes, Steering & Suspension 7 10-11-2001 10:26 AM
Brake upgrades for 02 WRX bWRX Brakes, Steering & Suspension 8 05-29-2001 10:41 PM
