Old 03-16-2004, 09:30 AM   #1
sj72
Member#: 47399
Default Part Numbers for Differential and Auto Tranny Drain Plug Gaskets
Anyone have the part #'s for a Legacy 02 auto-tranny drain plug gasket and the gasket for the front differential drain plug?
I know that you need to replace the auto-tranny and front diff drain plug gaskets when you drain the fluids.
I have searched the forum but have not seen these part #'s as of yet.
Thanks
Shane
sj72 is offline   Reply With Quote
Old 03-16-2004, 12:30 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The tranny pan is the same as the oil pan- 11126AA000. The drain for the diff is 803926070.
Brian
Old 03-18-2004, 04:22 AM   #3
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
There's a gasket on the drain plug?
Mine didn't have it on my 02 OBS 4EAT...
CheezeWeezle is offline   Reply With Quote
Old 03-18-2004, 08:53 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Um, it should .
Brian
Old 03-23-2004, 03:38 PM   #5
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
Hey, while you're at it, Brian, how about part numbers for any gasket that is needed for the 5MT drain nut? Does it even have one? thanks.
Sir_Xenon is offline   Reply With Quote
Old 03-23-2004, 05:22 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Yep, it uses the same 803926070 the 4EAT does .
Brian
Looking for a part number for a 5 speed tranny wiring harness Cyclops Transmission (AT/MT) & Driveline 0 06-09-2009 11:40 PM
Tranny drain plug gasket? Hendathor Service & Maintenance 3 05-29-2009 07:45 PM
part numbers for front and rear tophats + front conical washer? alpnwhite96 Brakes, Steering & Suspension 0 08-27-2007 02:37 PM
bg5 auto tranny drain plug leaking? Benjamin Tang Legacy Forum 3 07-01-2002 01:18 PM
differential and auto tranny fluid Kevex Service & Maintenance 4 03-11-2002 10:36 PM
