Old 03-16-2004, 05:20 PM   #1
100
Member#: 10034
2002 WRX Wagon
WR Blue. niiiice.
Default Talk me out of Koni inserts + Ground Control coilovers
This is for my 2002 WRX Wagon on 225/45-17 rubber. I'm getting the coilovers so that I can raise the rear if it starts rubbing.
I don't intend to install top mounts. Is that okay? Is there anything else I need to order besides the inserts and coilovers?
Can anyone forsee any problems with this system?
100
100 is offline   Reply With Quote
Old 03-16-2004, 05:54 PM   #2
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Toss in a set of 14mm camber bolts for the rear. It's a good (perhaps better than raising) way to get the clearance you need to avoid rubbing.
nunyo is offline   Reply With Quote
Old 03-16-2004, 06:04 PM   #3
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
whats up.
You wont need to get top mounts if you use the konis. The only reason I used the topmounts on my setup was because my struts were sedan-specific. With the konis, you use your original struts and remove the shaft and such to install the new inserts. That would be a beautiful setup. There is no way I am talking you out of it. haha ...however, you could always get them for me...haha jK
-Jack
brazymstrp is offline   Reply With Quote
Old 03-16-2004, 06:10 PM   #4
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
100
If your problem is rubbing, then thei will definitely help, albeit, not directly in the manner in which you stated. So while, yes you can raise it to help prevent rubbing, stiffer coils will drastically decrease the likelyhood that the suspension will compress enough to actually get to the point of rubbing. *Even when lowered below stock!*
Additionally, i agree with the folks above in that adding some simple camber bolts to the rear will help dial out any rubbing as well. Additionally, you don't need stiffer stop mounts at all.
So sorry, i can't talk you out of this one... in fact, it sounds like just the prescription you need! (provided your wallet agrees, thats not my call)
Cosworth is offline   Reply With Quote
Old 03-16-2004, 06:36 PM   #5
YinUCSD
Member#: 44945
06 LGT wag
you dont need new top hats.
what springs are you currently running and what is the offset of your wheels? because if your wheels are the correct offset you wont rub even if you are lowered, but not too much.
YinUCSD is offline   Reply With Quote
Old 03-16-2004, 06:36 PM   #6
D_REX
Member#: 8945
MY02 WRX
While you may not NEED stiffer top mounts they would certainly be a good thing. With stiffer springs your struts will be working harder. The only thing connecting the top of the strut to the car is the top mount, the softer the rubber the less efficiently the strut can do it's job. It's kind of like the stock endlinks, they really aren't that bad under a static load but they add a good bit of lag in the transitions.
Koni / Ground control is definitely the way to go I'm headed that way myself
Later,
Dustin
D_REX is offline   Reply With Quote
Old 03-16-2004, 10:05 PM   #7
Mark Avery
Member#: 10313
2002 WRX wagon
Don't worry about rubbing, just get the fender lips rolled.
Mark Avery is offline   Reply With Quote
Old 03-16-2004, 11:38 PM   #8
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
This is all true. Furthermore, it becomes more true, the stiffer a set of coils/dampers you use. With typical Eibach, H&R's, SPT, etc, you would not need them, however, if you're running some 400# coils, it would be a critical item. All points inbetween, its a tossup and your call. But know that it will never hurt to have them. Unfortunatly, we don't have any concrete figures as to the threshold when you should really have them. It unfortunate that the rear's are so expensive.
Old 03-17-2004, 12:46 AM   #9
100
Member#: 10034
2002 WRX Wagon
WR Blue. niiiice.
I need to choose spring rates, and they ain't gonna be no 400. What are some good rates if I commute and track/autoX?
Old 03-17-2004, 07:46 AM   #10
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
I'm thinking about adding GC's to my existing Koni setup as a replacement for the current Prodrive springs...
So a 'bump' for more spring info.
Scott
sdecker is offline   Reply With Quote
Old 03-17-2004, 09:41 AM   #11
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I have a great street kit for sale... the rates are very comfortable, yet provide a nice balance of handling.
http://forums.nasioc.com/forums/show...hreadid=521254
The specs are the ever popular 9", 280# front and 8", 250# rear spring. A search will yield many other satisfied folks with this combo. Any less than that and you are in typical Eibach/H&R coil rate ranges.
Old 03-17-2004, 01:31 PM   #12
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
I just sproke to GC and they were very adomant about not going below 300# on the front. They said that there is good chance of coind bind when lower then that due to linear rate of the springs.
Anyone has a coment on that?
The guys there are saying that 300 / 250 is going to be good on the street and will let you run good at auto-x.
Alex...
Alex Performance
amelnikov is offline   Reply With Quote
Old 03-17-2004, 02:18 PM   #13
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Thats not entirely true. I have a spreadsheet that i use to calculate all the values for ride height, coil bind, travel, static rest heights, etc and there is plenty of travel left in those combos. Especially since the front is a 9" spring. For instance, on a WRX sedan, the 9" 280# spring will have 2.19" of travel beyond static rest height left (and taked 615# to do it) vs a 300#, 8" spring which has only 1.81" left of travel (541# required). Similarly, a 7", 400# coil has 1.98" remaining (790# required). A 7", 300# coil would not be as advisable as it only has 1.32" remaining and would only take 395# to compress it.
So you can go less than 300#, but you need the length of a longer spring to get you the travel you need.
Another thing to remember is that you are going to lower the car some and as a result, you will not need much travel. From the numbers you see above others that i have calculated, you are generally only going to have about 1.5"-2.25" or bump travel in these springs. Thats it! However, when you lower the car, you really reduce the amount of bump travel in the shocks as well. Generally speaking, you will have about the same amount of bump travel for the shock as you have for the spring... sometimes even less. Remember though, the stiffer the spring, the less likely you are to atually bottom out the spring and not the shock. I can't ever remember bottoming out my 9", 280#'ers.
Hope this helps,
Jon.
Old 03-17-2004, 02:24 PM   #14
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Thanks Joh.
Alex...
Alex Performance
Old 03-17-2004, 04:33 PM   #15
Gonz
Member#: 18642
2005 Impreza WRX STi
Hope this helps,
Jon.
Ditto. I've never bottomed out on this same setup (with Konis ).
You can still cross railroad tracks, speed bumps, crowned roadways, etc. at a decent speed. You will definitely feel more of a jolt than with stock set up, but bottoming out has never been an issue.
Keep in mind the force quoted to bottom out these springs is per side. So over 1200 pounds total.
If you had stock struts you might have to worry about it, but you don't
Gonz.
Gonz is offline   Reply With Quote
Old 03-17-2004, 04:50 PM   #16
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Gonz.
Gonzie, how ya been chief?
He's right fellas, and furthermore, the 1200# for the whole front end is on top of the ~1800 lbs of static weight already weighing it down!
FS: coilovers, koni inserts, ground control sleeves Sir Punk 1993 - 2001 Impreza Specific Parts 4 08-05-2008 01:23 PM
FS: coilovers, koni inserts, ground control sleeves Sir Punk Suspension/Brakes/Handling 5 07-31-2008 11:09 AM
Rear Camber Plates + Koni Inserts + Ground Control Coilover Kit compatible? rlavalle Brakes, Steering & Suspension 6 10-31-2005 07:22 PM
The Koni insert / Ground Controls install has begun (long) Patrick Olsen Legacy Forum 23 07-28-2004 03:25 AM
Anyone using Koni inserts + Ground Control Gonz Brakes, Steering & Suspension 5 06-21-2003 10:54 PM
