Old 03-16-2004, 05:31 PM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default USDM wrx exhaust on JDM ej20G motor
so I'm looking for a turbo back on for my jdm EJ20G in my GC8. I've heard the TD05's are monted differently so would a USDM turbo back work fully? since the JDM Ej20 is obd II it wont have a 2nd 02 and the usdm wrx down pipes do have a hole should that just get welded shut? I do have an sensor or an exhaust temp sensor that goes in to the jdm down pipe soo I'd have to cut a new hole for that? and I'd have to shorten the down pipe 2 inches correct? anything else? isn't there a exhaust hanger that doesnt line up or is on the other side on the GC8 body style when using usdm wrx exhaust? which one doesn't line up? that could just be cut and weld to the other side correct?
anything else need to be modifyed? I plain on having my boss do the welding
scobaru is offline   Reply With Quote
Old 03-16-2004, 06:13 PM   #2
Structure828
Member#: 50488
1999 GC8 ej20g!
Get something custom made, you get more power...its custom, it sounds better, and looks better...and sometimes its cheaper.
Structure828 is offline   Reply With Quote
Old 03-16-2004, 07:58 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I looked in to it and it ended up being like 950. the turbo back set up i'm looking into I've heard before on a USDM wrx and I like it. the custom one theres no real R&D that goes in to them its more or less well this looks like it'll work or well we gotta bend it here beause it'll get in teh way of this
Old 03-16-2004, 09:50 PM   #4
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
The USDM exhaust will work. The difference with the TD05 isnt the exhaust mounting location, its the intake.
Old 03-16-2004, 10:58 PM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
okay what part of the cat back doesn't mount right?
Old 03-16-2004, 11:06 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
hhhmmm,
The EJ20G sitting in my garage has 2 o2 sensors...
Old 03-16-2004, 11:43 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you could use the catback and all so long as you had a custom downpipe made that meets up with the other piping. That is probably the easiest solution.
Take it easy, Micah
Old 03-17-2004, 12:18 AM   #8
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
The full turbo back will bolt up and fit right from what I know, sans the one muffler hangar (that will either need to be cut off, or moved IE re-welded)
As for the extra 02 sensor hole, if you have to plug it just use an old 02 sensor, or find a bolt that will fit it. Plugging it up with a weld might not be the best idea.
Old 03-17-2004, 12:50 AM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
oh okay cool I guess I can use my EJ18's o2
Matt Monson is your ej20G an european motor? I think they had the 2nd 02
Old 03-17-2004, 11:32 AM   #10
Puckaveli
Member#: 1518
00 2.5RS
My JDM EJ20G has one 02(header) and an EGT(downpipe). The UK diagrams show only one 02 and no EGT.
I just bought a Scoobysport turboback for mine so it better fit.
Puckaveli is offline   Reply With Quote
Old 03-18-2004, 11:56 AM   #11
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
that is exactly what i did
i zip tied the connector to the downpipe/tranny mount to keep it from flappin' around
USDM Exhaust on JDM V7 STI Swap? Zaider Subaru Conversions 2 10-21-2009 05:59 PM
Post-Swap Sale: LOTS of leftover USDM GC8 EJ25 and JDM EJ20g parts!!! tweakling Private 'For Sale' Classifieds 21 08-17-2006 03:52 PM
Post-Swap Sale: LOTS of leftover USDM GC8 EJ25 and JDM EJ20g parts!!! tweakling MAIC Private Classifieds 0 07-12-2006 09:39 PM
USDM WRX exhaust vs. JDM STi exhaust hey1 Factory 2.0L Turbo Powertrain 6 11-27-2004 02:00 PM
USDM WRX ecu on JDM blaznc Subaru Conversions 2 01-28-2004 04:34 AM
Message Board Statistics All times are GMT -4. The time now is 04:46 PM.
