Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-17-2004, 04:00 AM   #1
verendia
Member#: 54550
1995 LX
graphite grey
Question ej22t block w/ ej20 head
has any 1 put the usdm wrx head with the legacy turbo block? is it better then the 2.5 rs dohc head ? some 1 please help ..thanks
verendia is offline   Reply With Quote
Old 03-17-2004, 06:42 PM   #2
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
You can, but the compression will be lower... ~7.4:1
We made special pistons for the blocks and WRX heads.. Bringing it up to ~8.5:1
-Mike
MJU1983 is offline   Reply With Quote
Old 03-18-2004, 06:34 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
http://bbs.legacycentral.org
Lots of discussion on this topic has already taken place in 3-4 long threads.
Old 04-14-2004, 10:37 PM   #4
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
can you swap a ej2tt engine in with SOHC RS heads and run it on the RS ecu is my question?
benjaminetanyahoo is offline   Reply With Quote
Old 04-15-2004, 10:43 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
This has been to subject of some debate in recent months. But Opie is currently doing it, and a few others have done it or are in process. But long term reliability is still unproven. The big issue is that some folks don't think enough of the coolant passages line up to have long term reliability...
Old 04-15-2004, 03:15 PM   #6
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
coolant passage lines on the short block? Or are we talking about the famous oil squirters? Please enlighten me thanks
Old 04-15-2004, 06:42 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Old 04-15-2004, 06:52 PM   #8
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
wow pretty good stuff, so I guess a SOHC RS head doesn't really work with a ej22t shortblock, hmmm interesting
Old 04-17-2004, 07:06 AM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Originally posted by Matt Monson
http://www.legacycentral.org/library/headswap.htm
coolant passages...
Good stuff...
Heres a thread with all the links to the ej22 threads on here.
http://forums.nasioc.com/forums/show...highlight=ej22
Old 06-02-2004, 03:06 AM   #10
SJwrx
Member#: 14970
1997 GF8
multi
www.axispowerracing.net does it day in and day out
Rich
SJwrx is offline   Reply With Quote
Old 06-02-2004, 10:33 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
Rich
Um,
you are a little late to the show, like 3 months late. And the first response in this thread was Mike from Axis...
Old 06-02-2004, 11:58 PM   #12
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
i have heard that the dohc heads work better then he sohc heads, i have yet to see the heads up close.
subiekid is offline   Reply With Quote
Old 06-03-2004, 12:18 AM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Work better? They dont flow better... the SOHC heads out flow the DOHCs.
Old 06-03-2004, 01:59 PM   #14
SJwrx
Member#: 14970
1997 GF8
multi
Um,
where should I send my written appology?
Rich
Old 06-03-2004, 10:29 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
Rich
Old 06-20-2004, 12:13 AM   #16
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Yeah but wouldn't DOHC be better for high hp turbo apps to control the timing better? I dunno. BUT I'm doing the EJ20 head swap onto a 1991 EJ22 turbo/closed deck block within the next few weeks...I'll let ya know!
WRX34
WRX34 is offline   Reply With Quote
Old 06-26-2004, 07:38 PM   #17
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
i am doing a ej20 ( wrx) head swap onto a ej22t block. tere have been a couple of things that needed to be modified to make it work. legacy oil pump is on order. i used the stock heads with the ej22t head gasket. took the butterfly valves out of the tgv housings and had to cut and weld up the top crankcase vent to let the coolent passageway fit. we havn't started it yet but i will let you know when we do.
also we noticed that with this setup the stock cast exhause manifold wouldn't go back on. the ej22t is apparently several mm taller. we had to stretch my gpmotos to get them to fit.
wrxtuner02 is offline   Reply With Quote
I have a EJ25 short block with EJ20 heads Crazy650 Built Motor Discussion 16 07-06-2009 11:19 PM
FS: EJ22T block, DOHC EJ25 heads deamon64 Engine/Power/Exhaust 2 04-07-2009 10:36 PM
ej25 turbo block with ej20 heads? soslow Newbies & FAQs 3 01-06-2008 08:22 PM
EJ22T block with WRX head of Built USDM WRX block Cstmboxermotorsports Built Motor Discussion 15 10-18-2006 07:02 AM
EJ22T Block on EJ20 WRX heads blaznc Subaru Conversions 1 02-08-2004 11:06 PM
