Old 03-17-2004, 09:32 PM   #1
DanZ
Member#: 21970
MBP wingless WRX
TMS Tuned / [email protected]
Default Omori 52mm faceplate in OEM pod?
I got the impression that the Omori 52mm angled faceplate doesn't fit in the OEM pod. Is this possibly with some minor modification? Has anyone done it or seen how much cutting it would take?
-Dan
DanZ is offline   Reply With Quote
Old 03-18-2004, 02:45 AM   #2
DanZ
Member#: 21970
MBP wingless WRX
maybe this should be in the interior modification and care forum? bump
Old 03-18-2004, 09:18 PM   #3
DanZ
Member#: 21970
MBP wingless WRX
bump. I want to do this!!
Old 03-19-2004, 10:47 AM   #4
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
If you are talking about the oem pod that sits on top of the steering column, that is made for a 42mm gauge. Omori does sell a 45mm gauge that will fit, but it is a tight fit and will not recess in the pod as much as the stock gauge.
skyhawk is offline   Reply With Quote
Old 03-19-2004, 12:04 PM   #5
DanZ
Member#: 21970
MBP wingless WRX
What if I cut the opening in the oem pod to make it bigger? Does anyone know much cutting would be required? thanks
-Dan
Omori Gauge Set in OEM Housing / Derres Faceplate $250 Brian Broz VIC Private Classifieds 13 03-01-2008 04:09 PM
52mm Greddy gauges in oem pod wrxxed Private 'For Sale' Classifieds 9 07-16-2004 12:47 AM
Where to get mount plate for 52mm gauge for OEM pod? jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-28-2002 03:04 AM
Question to those with Omori 52mm guages in center of dash. Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-13-2002 03:16 PM
