Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 03-17-2004, 08:48 PM   #1
azimiut
Member#: 43426
2002 Aspen White WRX
STI Swap Dynocomp tuned
Default Quick help its getting dark, Headlight question!
ok, first my stock lights broke, the lens shatered, so i got some replica WRC's for $25. i got the wiring from Scooby Mods . so, in the instructions, it says to put the pos to battery. ok, if I do this, the light will be on ALL the time. do i need to connect it to a wire that is on with the ignition? also, before i made the new wiring for the lights my fogs would not go on, so.... i put my stock lighs back in and the fogs work fine. also my hi beam light is on, on the dash all the time if my lights are on. i am doing one light at a time so i dont have to screw up twice. thanks and help ASAP.
azimiut is offline   Reply With Quote
Old 03-17-2004, 09:07 PM   #2
WReX'n'Effect
Member#: 22368
2011 WRX Limited
Obsidian Black Pearl
can't you just tap the wires from your stock wiring?
WReX'n'Effect is offline   Reply With Quote
Old 03-17-2004, 09:11 PM   #3
azimiut
Member#: 43426
well they are already gonig to the relays. also, from what I understand is that ther is no need to cut any factory harness. playing with it just now, i cannot get the relay to turn off once it has turned on. so the lights will not come on until I turn them on, but the will not turn off, even with the key taken out. sinec I do not know enough about how the relays go, I dont want to start "trying" things.
Old 03-17-2004, 09:19 PM   #4
WReX'n'Effect
Member#: 22368
2011 WRX Limited
true I'm no electrician either, hopefully someone else will post, sorry i can't help. Good luck, later.
Old 03-17-2004, 09:25 PM   #5
azimiut
Member#: 43426
thnx though
Old 03-18-2004, 09:38 AM   #6
tux
Member#: 40949
2003 wrx
wr blue
tux is offline   Reply With Quote
Old 03-18-2004, 10:17 AM   #7
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
were you trying to use the first sec of instructions with 2 relays, or the second with three? It would help to know what exactly you've done.
The wire that goes to battery positive leads to a relay, so no, the lights won't be on all the time. The way the relay works is when the headlights are on, it's activated, transmitting the power directly to the lights from the battery. I'm not sure why the lights would just stay on, however.. more info would help.
bleuquila is offline   Reply With Quote
Old 03-18-2004, 12:11 PM   #8
azimiut
Member#: 43426
im doing the first set with 2 relays. i understand how they work, and I got one hradlight done last night, go to get the second one. di dit exaclty the same and I have no lights at all. where is a good IGNITION ON i can go off of? if i go strait to the batery, there is always power there, so the lights will be on, i need to find a power source that is ignition on.
Old 03-18-2004, 02:21 PM   #9
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
well, if your harness plugs into the stock headlight wires, I really don't understand what the problem is If you follow the directions in that diagram, the low beams will be on with the headlights are on, or else when the ignition is on, depends if you disabled the DRLs or not - the power to switch the relay comes from the common 12, not the battery. and the high beams will be on when they're supposed to because the relay terminal 86 grounds to the subaru hi-beam switched ground.
sorry if you already know all this, but I can't figure what you're asking.. you shouldn't need to locate a different ignition 12V source underhood when you've already got a perfectly good one.
and.. so you did one light and it worked, but when you did the second one, now neither work? I really can't follow.
Old 03-18-2004, 11:35 PM   #10
azimiut
Member#: 43426
I the power i found blew the fuse. I got it fixed. I do not know where to get the common 12v source. that is my only problem. the actual wiring from relays and what not worked.
Old 03-19-2004, 10:39 AM   #11
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
The wires that plug into the back of the 9007 stock headlamps - there are three wires per headlamp. The two outside wires are grounds, the center wire is 12V, it will come on with ignition if you have the DRLs intact, or else it will come on when you turn on the lights if you removed the DRL module. On the driver's side it's a Red/LightBlue wire, on the passenger side it's LightBlue/White. hth.
Old 05-02-2004, 02:43 PM   #12
deebo
Member#: 50082
02 wrx cobbstage 2
mbp
did you find out how to get these to work ?
deebo is offline   Reply With Quote
Oh man...its getting dark already! GooseMan Off-Topic 16 10-30-2006 06:51 PM
Gauge help, its gettin dark outside anthony_delprete84 Newbies & FAQs 26 10-04-2005 01:08 PM
Need quick help clearing one (1) headlight. 04RCSTI New England Impreza Club Forum -- NESIC 10 02-19-2005 12:56 PM
help before it gets dark! RSB problem DoctorNick Brakes, Steering & Suspension 6 01-11-2002 12:57 AM
('93-'01) quick headlight question a yes or no Seth W Impreza Forum 3 04-10-2001 08:04 PM
